I hate to see folks sawing away at filter pleats. Risky for fingers, and tends to contaminate the media.
Get a sharp knife with stiff blade about 4" long. Plunge the tip through the media so the tip is tangent to the core tube, then lever downward. Repeat.
I’ll just throw this one out there as well…….
https://www.kitplanes.com/oil-filter-slicer-off-er/
I use this
https://www.aircraftspruce.com/catalog/topages/tempestOilCutter.php?clickkey=4975
Anything without some sort of blade guard or whatever just makes me cringe, imagining slicing open a palm or fingers.
https://www.aircraftspruce.ca/catalog/eppages/challengerLifetime_08-06017.php
This would certainly simply things.
Tim
Or try side cutter dikes with long enough cutting nose to reach deep in the pleats. You may not get the very inner pleat area but that'll just pull out once you get both side cut.
It seems that would be printable.
