Ross7A-builder
Can anyone comment on the pros and cons of using the stock VAN's fuel selector valve versus buying the ANDAIR valve?
16 years, 1515 hours, trucking right along. Disassemble and lube every couple years when it feels stiff, otherwise no issues of any sort.Can anyone comment on the pros and cons of using the stock VAN's fuel selector valve versus buying the ANDAIR valve?
If this is for Van's original, I agree! Fuel lube on the plunger every other condition inspection unless it feels good, then leave it alone until it starts to stiffen up. I don't believe I have ever had to replace the "O" rings either and no leaks. I have some just in case. Got them at JAX Farm and Ranch supply. Simple.
The Andair is expensive and has a long backlog, but once you have it and you use it, you'll be happy. "Buy the best and you only cry once."
Order the FS20x7T valve.
Tom
One thing not mentioned is that Van's "Tractor" valve…goes through an "off" position when transitioning from Left to Right tanks. Not necessarily always a good thing.
HFS[/QUOTE
From a pro and con standpoint, this might be the stock valve’s biggest con.
However, this “con” doesn’t seem to be an issue in practice.
I believe that the current Van’s valve replaced an older valve long ago that was more prone to galling and binding.
IMHO: the Andair valve is better and nicer but only worth considering if the look and feel float your boat. The stock valve is functionally “good enough.”
"One thing not mentioned is that Van's "Tractor" valve…goes through an "off" position when transitioning from Left to Right tanks. Not necessarily always a good thing. From a pro and con standpoint, this might be the stock valve’s biggest con."
Van's fuel valve can be installed with 90 deg. L to R. Or 180 deg. L to R. It's up to the installer. there are three inlets that are horizontal and one vertical outlet. You can connect three tanks or just two and plug off the one not in use.
