The seat cushions arrived, un-upholstered, from Oregon Aero for a test fitting. They need a fair bit of rework, so it was good to have them to assess what’s next. They are now back at Oregon Aero. If you’re considering custom seats, consider adding two or three iterations of shipping to the estimate.
Continued tweaking the cowl, and like many of you, it’s a frustrating experience for me.
Then I had a bit of inspiration - since I was taking the cowl on and off so much anyway, why not use those cycles to trim the baffles? Turns out that although the baffles are a welcome change from the fiberglass, they are mutually incompatible. - if the baffles don’t fit the cowl won’t, and then there’s no cowl work to be done. I started by omitting the forward half of the baffles because they won’t go on without trimming. The back ones will since they only contact the upper cowl.
After some trimming (and over-trimming the RH aft piece, replacement part on order) I was ready to try the paperclip trick. Here are some paperclips after a couple of cycles of measuring and adjusting. I learned some things about this.
1. I didn’t know if a standard paperclip would work so I got large. This proved a reasonable idea.
2. As you can see, I am doing this with the blue vinyl on. This gives a somewhat slipper surface for the paperclips to grab, and I had to slightly bend each paperclip to increase the grabbing force. Paperclips might work better on bare aluminum.
3. The paperclips tend to bend over sideways. Measure from the apparent surface of the cowl to the baffle. Instead of measuring in a vertical direction, the measurement is perpendicular to the baffle contour line.
Since I was afraid of over-trimming other pieces, I took it slowly. Slowly, in this context means lots more reps of measuring, trimming, reinstalling paperclips, fitting the top cowl, repeat.
For me, trimming was either with snips or the bandsaw. For most cuts, the bandsaw was much easier. For short fairly straight cuts, and there weren’t many of those, snips worked perfectly fine. If your snips cut .032 aluminum like paper, hey, go for it. For mine, .032 is close to the limit.
So far, I haven't the slightest idea where I'm going to mount my non-standard oil cooler, except that I'm hoping to put it forward of the firewall.
Dave
