Got a question for all you guys with strong magic. I'm about ready to do the ribs on the fuel tanks this week and have read Rick6A's and everyone else's fantastic posts on pro-seal. Great words/pics. The plan is to do all five ribs at once. What I can't quite figure out is should all the required sealant be mixed up at once or in batches? Also, is it better to apply the sealant to the upper portion of all the ribs/skin (after the nose area is sealed/clecoed) and then cleco them all at one time and then seal the lower portion of the ribs/skin and cleco all of them? I live in Co Springs so the garage will be in the high 50s / low 60s this week when all this takes place so the working time will be around 1+30-ish. Hopefully this makes sense as I still get a bit of a helmet fire on this stuff. Thanks for your support!
Chris,
Have you reached out to Hank Cheng (Lots about him on VAF)who built the RV-8 in Hong Kong a few years back? His build was sponsored in part by the HAECO group MRO in Hong Kong,( I work for HAECO Americas in the US), and they use a LOT of Proseal. There may be some local connection or supplier that could assist.
Having read through all these excellent posts, one thing I am hoping is someone has copies of rick?s original images? They all don?t seem to work anymore.
Outside of the tanks, what areas need Proseal and how much is needed?
... This thread started 15 years ago - any updates or issues anyone who has used this method has noticed in that time? Any reason not to do it or gotchas people have stumbled on?
Photos are probably lost to time. I used the "fay seal" process and so far the tanks are happy. I have photos on my blog if you want to review. Shoot me a Google g-mail address and I'll send an invite.Almost 3 years later, I have the same questions. Anyone?
Any luck locating the pictures?
Not a problem to reapply over cured sealant as long as nothing has happened to cause any surface contamination.Awesome thread. I read this and did not see ProSeal reapplication addressed. I have a couple of filet spots and rivet heads that I think need more sealant on. The original proseal application is about a week old. What is the procedure for fixing voids etc?
Denatured alcohol and a clean cloth should be sufficient ( don’t use plain paper towels).Thanks Scott and Dave.
I did the stiffeners so far and looking at Dave’s diagram that I might be light in more areas. I’ll look at that today. I might need to obtain some type A and slather on.
With regards to contamination, I had the tanks covered but not hermetically sealed so some light dust exists. I’d feel better if I could clean this up prior to applying more proseal. What should be used?
A question for Scott or others with more experience with leaking tanks. Working on a leak that is at the fuel pick up location and the leak is thru the NPT thread of the fitting. We have used multiple fittings (some new) with different sealants (Loctite 565, 567 and others) with no luck. Considering the fact that removing the female fitting inside the tank may cause more problems then the small leak we have, I am thinking of using proseal in place of Loctite, knowing well that it will make the removal of the fitting very difficult.Denatured alcohol and a clean cloth should be sufficient ( don’t use plain paper towels).
Yep--1422 is brown, and my "go to" tank sealant. I lake to assemble with "B" and topcoat with "A" which is thin and brushes on smooth .Great thread. But have a question: bought PRC PR-1422B2 and the color is brown not white (part B,
not mixed) ? Is that ok? I have never seen tank sealant brown, always grey or white (part B unmixed). Part A is black.
Thes plates are brush topcoated with 1422A 1/2 after they were installed with 1422B1/2. You can see how nicely it flows out.Yep--1422 is brown, and my "go to" tank sealant. I lake to assemble with "B" and topcoat with "A" which is thin and brushes on smooth .
If you are referring to the rib flutes (made to straighten the rib flanges) or the spaces between the radius flanges, yes. I seal everything.One last question! When fileting, does one apply a filet over the rib flange reliefs?
Thanks.Probably been posted before but Scott did an excellent video on building RV fuel tanks.
Well worth a watch if you’re about to do it.
Fuel Tank Building
@BavafaA question for Scott or others with more experience with leaking tanks. Working on a leak that is at the fuel pick up location and the leak is thru the NPT thread of the fitting. We have used multiple fittings (some new) with different sealants (Loctite 565, 567 and others) with no luck. Considering the fact that removing the female fitting inside the tank may cause more problems then the small leak we have, I am thinking of using proseal in place of Loctite, knowing well that it will make the removal of the fitting very difficult.
With that in mind, I was wondering if you have any other suggestions/thoughts in this situation.
Hi Mark,@Bavafa
I'm dealing with the same issue. How did the ProSeal work for you? Did you use B1/2 or B2 and how long did you give it to cure before adding gas?
