Poll: Van's Twin
Should Vans build a Twin like the Rutan Boomerang
  • Yes - as a 4 seater
    Votes: 13 8.4%
  • Yes - as a 2 seater
    Votes: 4 2.6%
  • No
    Votes: 138 89.0%
  • Total voters
    155
  • Poll closed .
It’s just so ugly.. how could anybody want to build and fly something so hideous? lol
velocity
I actually was going to build the Velocity XLRG before I started my -10. Had an entire kit lined up, worked with the previous owner, had money in hand. The day before we were to close the deal, I get an email saying that he sold the kit...
That was a dick move, for sure...but...it pushed me into the -10 and I am happy it did.
The V Twin is nice but given the choice, I would build the TXL...250+ knots at altitude would be really nice! You are, however, going to pay dearly for that performance.
No, I really love my -10. Flies great, carries what I need, and will go just about anywhere...
I’m with Brian. Yes to a twin, but make it conventional like the Derringer. No Bommerang type. A 14 with two O-320s would be about the sweet spot.
Biggest problem I see is that the natural tendency to want bigger engines than recommended would be a much bigger issue than say an O-360 powered -9 or a Rocketized 6, 7 or 8. If I were Van’s that would be enough to scare me away from it. But I’d love to build one.
Wing Derringer type...
Make it a knockoff of the Wing Derringer. Two-seater with a larger baggage area. Retractable. Have a variety of engines available for it. O-320 up to the new IO-390-EXP119. If you really wanted it to be a high performance twin, go with two UL Power UL520T engines (220 HP). Not only are they much lighter, the turbo-normalizing gets you power up high (S.L. power up to 15,000 MSL), and they even come in a counter-rotating version (no critical engine...). However, I would never expect Van's to go with a UL Power engine. It would be an impressive aircraft if they did.
I'd make a similar to the -14 but with either doors like the -10 or a combination slider/doors (slide the canopy back, open a low-height door forward and step in). I'd probably do four tanks like a Glasair Sportsman but make them "wet" like RV's. Lots of fuel for range. You use a Facet pump to transfer fuel from the outboard tanks to the inboard tanks. How much fuel? As much as you can get!! Just like other aircraft, you can offload payload to fill up with fuel or vice versa.
No pressurization. Too complicated and too heavy. Keep it light and simple (if you can call a retractable twin simple...).
Due to the increased utility of something like this, some sort of deice would be great. Again, I wouldn't expect Van's to go out on a limb for a deice system. A "weeping wing" or a "thermal" system would be nice. Each have their respective advantages and disadvantages. If you make the leading edge "bolt-on" similar to how the tanks are attached, you can swap out leading edges with or without a deice system. It would probably be best to have the wet fuel tanks in between the front and rear spars if that was the case.
Anyway, I've wasted too much time typing about this.
Jeff
Jeff, I quite like where you're going with this. Nice big tail and rudder for single engine controllability. Big engines for single engine performance. It needs to be so good on one engine that the saying "second engine takes you to the scene of the crash" doesn't apply.
If we're sticking de-ice systems on this plane, then it needs big engines to keep performing when the icing gets bad too. The turbo UL520 sounds wonderful.
4 seats though, need the seats.
Would it sell? Would people build it? I'm guessing not many. Same problem as described the 6-seater thread. The plane would simply be too big and complex.
Only too big and complex if we make it so.
2 seats
Moderate engines- O-320
Fixed gear. Retracts are a waste under 200 kts. Also improves Vmc.
Need boots or 4 seats? Go buy a Baron or 310.
Yep, I agree with you David. I understand the Derringer had pretty good engine-out performance. Like you said, big engine, big tail, and you also need to be lightweight (read: high HP to weight ratio) to get good single engine performance. To help out on the S.E. performance, just don't load up with fuel and payload and stay light if you're worried about an engine-out scenario (mountains, night, etc.). Once you're out of the "danger zone" you can land, tank up and fly heavy, with a lower S.E. service ceiling.
That's one of the main reasons I said to have huge fuel tanks. So that even with half full "main" tanks you still have good range in the aircraft. You're going to want to have around 180 gallons total fuel capacity with this aircraft. 30 gallons in the outboard tanks (each tank) and 60 gallons in each inboard "main" tank. The UL520T typically burns 8-11 GPH so full tanks should give you about 9 hours before you're a glider. That's a LONG flight!!! With 30 gallons in each main tank, you're talking a 2 hour flight with a 45 minute reserve. The Derringer supposedly had a 184 kt cruise speed. I would expect with the more powerful engines you would be going faster but this still gives you about a 350 nm range with a 45 minute reserve. That can get you past a lot of "bad" territory.
Maybe a compromise on the seats would be to do what is done on the Sportsman 2+2. You have two, full size seats in the front and two aft facing seats in the back. The aft facing seats share a common seat back that can be easily removed via four bolts to make room in the back if you want to pack the back with cargo. The rear seat "bottoms" are attached to the seat back via piano hinges and are removed with the seat back (it's all one big assembly). The piano hinges allow you lift up the seat bottoms to store small items under the seats when they are installed. It's a really nice setup. The seats in the back can easily fit a couple of kids or small adults. Plus, they work great for tossing baggage on them. Just Google "Sportsman 2+2 aft facing seats" and look at the images. Some people had forward facing seats in the back but the head room was limited as was the allowable load due to C.G. concerns.
The aft facing seats have some good qualities to the design.
1) It keeps the C.G. close to the front seats when you put people in the back.
2) You get more head room for those in the back since the fuselage has a larger cross section there.
3) Both the front and rear seats, seat belts, headset wiring, etc. tie into the same bulkhead. You don't need to make two, relatively heavy, complex bulkheads with this arrangement.
Let's face it, most of the time you probably won't be flying with someone in the back seats. If you do, they will be facing backwards. Some people won't like facing aft during the flight. For them either put them in the front seat or leave them on the ground... :)
Would it sell? Yeah, I'm sure it would sell a few. How many? Who knows. A lot of people talk. Very few take action unfortunately... If Van's had something like Glasair's Two Week To Taxi (TWTT) program, then you'd probably get more takers. With the TWTT program, you're essentially trading cash for time. Also, the people who would most likely be purchasing an aircraft like this have the cash but not the time. The people who don't have the cash for a TWTT program wouldn't be purchasing an aircraft like this anyway.
It would be nice but again, I don't think Van's would do this. Maybe someone else will...
Jeff
Nope
I’m not a big believer in the concept of the light twin. Universally poor single engine performance on takeoff and added complexity are too hard to fix. By the time those issues are handled, it’s not a light twin any more. As I’ve said before, I’ve seen the Comanche, Arrow, Tiger and others transmogrified into twins. I don’t think any of those became better airplanes from that, they just became multiengine trainers. Light twins designed from a clean sheet (Crusader, 310, Baron, Travel Air, Apache… ) all those, did not do much better. Worst example of course, is the Lancer (twin Citabria,) an interesting but truly useless curiosity of an airplane. I don’t see that Vans has any magic to address these problems, nor do I think a Vans twin would “pencil out” as Greg Hughes might say. I for sure would not buy one or encourage anybody else to.
Only too big and complex if we make it so....
Given the innate complexity of having two engines, can you imagine a homebuilder NOT loading such an airplane up with gadgets and systems?
Fortunately the poll, right now, is running 10 to 1 against the concept.
Dave
Against Van's devoting resources to a twin...
Maybe someone else will step up...
If I was one of the many would-be builders out there that was watching my kit and parts shipping dates slip farther and farther, I’d be a little miffed at Vans devoting resources to anything other than current supply chain, manufacturing, and shipping issues, and I include the RV-15. I can’t imagine how that theoretical airplane isn’t years away from shipping its first empennage kit.
Dave
I can imagine all sorts of scenarios that would keep me up at night if I were Van’s. There is a difference between complexity added by the builder by larding it up, and complexity in the basic design (fixed gear vs retract for example) but yes, I get your point and I agree.
FWIW I don’t think Van’s will do a twin, and I’m not sure I’d want them to anyway. But for a fun little thought exercise, yes I would sure love to build one if they did!
The practical side of me agrees with you. The dreamer on the other hand…
If Van never put a little time into dreaming and R&D then the RV fleet would consist of a few dozen RV-3s and very few of us would be enjoying this hobby. Just sayin’.
Maybe we need another poll- “which is the worse idea, a 6-seater or a twin?”
That’s been discussed before; the R&D department has little control over parts, shipping, and supply chain issues. What would you have them do? I understand the frustration but most of the blame does not fall on vans.
Can’t say more than that as it will devolve into a political discussion and that’s not appropriate here…
Dreaming is one thing but that takes time, and time is money. There must be a ROI for the company and knowing what it takes to design, test, and execute a new aircraft, I’m pretty sure neither the twin or the 6 seater are viable options for the company…
It's not the mountains I'm worried about. In cruise, drift down and careful diversion planning can solve lots of that. My primary concern is flying away from the trees at the end of a 3000' runway when an engine quits just after there isn't enough space to stop.
Never heard of fuel tanks being too big. However, fuel tanks weigh more than not tanks. On our planes, how much heavier is the fuel tank than the outboard leading edge? They're roughly the same physical size, yet one is thicker skins, thicker ribs, extra brackets, bolts, sealant, and weighs much more.
Jim,
That is much closer to what I envision for an RV twin. I looked at this at Oshkosh last year and even talked to you briefly, along with about a zillion others, I’m sure.
I’d love to know more about single-engine performance and controllability with your setup.
Hi Jeff!
I’m sure it was a pleasure speaking with you at OSH! The engine out performance & controllability is as predicted. It slows to 105mph in level flight and if slowed to 90mph, will climb roughly 200fpm. This was performed at a zero thrust condition. Controllability like any other light twin. Definitely adequate to divert to a nearby suitable airport!
On takeoff, I have a self-imposed limit of 3500’ runways. I adjust that based on GW, density altitude & obstructions. If either engine fails during this critical phase, I simply pull both engines back and land straight ahead.
Not ALL twins should be treated equally…it’s all how you fly them! Anyone that spurts out the “good engine will take you to the scene of the crash” line, is not taking this into consideration!
Jim
Jim,
Good info. I agree with your dismissal of those who criticize all light twins and cite old saws. They strikes me as very similar to the misconceptions that surround tailwheel aircraft. Misconceptions which, incidentally, Van's designs have probably done more to rectify than any other aircraft in the modern era. But I digress.
A few follow up questions if I may.
You cite 90MPH as Vyse. How did you determine the zero thrust condition? Have you flown it with one caged? Under what conditions was this number determined?
What kind of Vmc testing did you do? What were the results? As I'm are you know, this is the thing that is most likely to bring a light twin to grief if not done correctly.
Is that 200 feet per minute based on sea level standard conditions? Here at my home field, in the summer, the density altitude of frequently around 8k', which would degrade that. That would be a limitation to the utility of your airplane, wouldn't it?
Dave
Jim,
My “zero thrust” setting is not a true number since I cannot feather the prop. It was performed with engine shutdown (prop locked…no rotation) at 3000’ with myself and 30 gallons of fuel. OAT was 62F. I did both my Vyse & Vmc testing at this time…both kind of crude numbers, but gave me an idea of what to expect.
Vmc…82mph
Performed with above conditions…raised nose and decreased speed until lost rudder authority.
Vyse…90mph
Maintained roughly 105-110mph at level flight. Raised nose to 90mph to get max ROC. (100-250fpm)
Once again, wasn’t looking to build “spaghetti charts” but just getting rough crude numbers. Performed at 3000’ back in Long Island during phase I knowing I would be moving it to North Georgia with a field elevation of 2700’.
Jim
Does anyone know what happened to the Wing Derringer design? Surely someone owns it or has the drawings or something? It seemed to be a great design.
Derringer
John Thorp designed the Derringer in 1958 as a development of the Sky Scooter. It was "taken over" by George Wing/Hi-Shear Corp. It was developed and certified with help from North American engineers. originally powered by Continental 0 200's with fixed pitch props, all but the first example were powered by Lycoming IO 320 B or C series identical to the Twin Commanche.
Hi-Shear has gone thru various name changes and owners and is still in business. It seems likely that Hi-shear owns the rights to the Derringer.
Both George Wing and John Thorp have been gone for many years.
I saw the 0 200 powered prototype at Rockford EAA in the 60's.
The reality is that most did not want a two place twin. A Miller Conversion Twin Commanche with additional speed mods with outperform the Derringer but the horsepower goes from 160 to 200.
Wing Derringer plans
Probably about 15-20 years ago I saw a Wing Derringer up for sale. In addition to the aircraft, the seller supposedly had a set of the production drawings for the aircraft that was included in the sale. Looking back I wish I had bought it. I was relatively broke at the time so no way could I afford it. Not sure how I would have made it happen but it would have been nice.
I thought that maybe someone could try to contact the owners of the Derringer aircraft out there and see if they have a set of plans for the aircraft. You'd pay them just to make a copy of the original plans so you can have them. Not that you'd make an exact duplicate of the aircraft but it would be a good starting point. A lot has changed over the years and using modern aerodynamic and structural analysis to the design along with CNC production of parts could yield some benefits over the original.
Again, not sure if it would sell or not. Most likely not...
Derringer construction complexities
A side note on the Derringer ,( there is one based near me), and my curiosity got me researching. It was designed/built by some airliner guys with resources consistent with big jets(as mentioned in earlier post). It used chemically milled skins that were also hydro pressed.not a cheap route. The aircraft was never really certified, and best I can understand, most were hand built by the design team, although some partially assembled "kits" were finished by individuals. Seeing the one fly into our airport and smoking it over, I was impressed, however, its much of a 2 seat retractable hotrod with twice the basic RV operating cost. When I first heard it coming, I thought it was a 2 -ship RV formation...a cool concept, but I question kit sales numbers vs. design/test/production cost.
Derringer
Where does this stuff come from?? See post 33. John Thorp was not an airliner guy. He designed a number of homebuilt airplanes, some of them intended for production, some strictly homebuilts. The Thorp T18 probably the best known.
My real question is WHY?
I can't order a new RV-14 kit and expect to receive it in much less than a year.
With a backlog like that and orders coming in every minute why take the time to do anything except build kits all ready sold.
My business sense opinion.
Art
Derringer
The Derringer that I saw at Rockford/EAA in the 60's was powered with Continental O 200's with fixed pitch metal props that were custom modified for the airplane. Those props did have problems as the prop concept did on many other airplanes. From the second airplane on the engines were identical to the Piper Twin Commanche. The props were Hartzell full feathering constant speed.
Thorp left Lockheed in 1946. His involvement at Lockheed with large airplanes was the P2V Neptune. NO AIRLINBERS.
Thorp did the preliminary design on the Piper PA28 Cherokee which was a four place derivative of the Thorp Sky Scooter.
The Thorp T18 was the first EAB aircraft to fly around the world.
Thorp was the first recipient of the EAA August Raspet Award, an award still sponsored by EAA.
Derringer
Derringer was type certified in 1966. Sir or seven production airplanes we5re completed depending on source. Seven unfinished airplanes were later sold. Nine Derringers remain on the US registry.
The statement about stretch formed chemically milled skins is correct. That was a process that Lockheed used dating to the Constellation and used on the Electra's and probably other Lockheed aircraft.
This information is widely available from multiple sources. Comments such as the "Derringer was never certificated" are hogwash.
Art
Yeah, no. The R&D guys have nothing to do with the building and shipping of previously ordered kits. I think vans is doing everything they can to catch up on the backlog while also looking to the future.
There is one builder extraordinaire who built a twin engine RV6
Here is the article of his endeavor. It can be done but even the builder thinks it is a crazy proposition to try. He probably grafted the RV7 tail to his RV6-T
https://generalaviationnews.com/2021/09/13/the-twin-jag-a-twin-engine-rv-6a/
Ernie Gann’s Derringer
Ernie Gann (yeah, that Ernie Gann… Fate is the Hunter, others…) came to the home drome (Santa Paula Airport in SoCal) many years ago to visit friends on the field. He arrived in his Derringer. It was a bee-you-tifully crafted airplane. The chem milled skins allowed good thickness for riveting while shedding the excess weight of the extra thickness where it was not needed. He was a nice guy, fun to talk to and he gave me an enameled pin of the Douglas A-4 in Blue Angels colors. Of course I still have it! In another life, I worked for a commuter airline that flew Handley-Page Jetstreams. They had chem milled skins and guesstimated it saved about 40 lbs. per airplane. The process is expensive. They formed the parts, did the chem milling majick, drilled and countersunk, then anodized each part. Then primed and assembled with chromate putty on the faying surfaces… and finally applied an epoxy paint to most on the inside surfaces. They were making dang sure it didn’t corrode like it’s predecessor, the Herald.
Thorp Genius, The Derringer re-defined..
I've always been a big fan of John Thorp. As mentioned previously, his genius was evident in many modern aircraft to this day. For me it was every walkaround on the T-38 and the F16. The full flying horizontal stabilizer "slab"(which improved Mach tuck resistance) was supposedly refined into modern aircraft design while he worked as an Engineer Apprentice at Lockheed. Whether he contributed to or was crucially part of that specific design is undocumented. However, it is engineered into nearly every modern Jet and John utilized it on the Piper Cherokee (T-16) Derringer (T-17) Tiger (T-18) and many other of his 30+ designs.
BTW the Thorp T-18 had RV "total performance" long before Van was tinkering in the barn with the RV-1. The Tiger is a superb Sport Aircraft that I personally (for pure flying qualities) prefer over my RV6.
Interestingly a good friend who constructed his Four at the same time as I built mine "annealed" ALL his rivets in a dental oven. One of several "reasons why" is that he'd heard a famous engineer (John Thorp) categorically recommended it as it had better strength (work hardening) and less fatigue.
Genius is timeless...
V/R
Smokey
Wing Derringer (Thorp T-17)
Well, I'm a big fan of the RV-10.
And I designed 3 concepts about the RV-10 with two Rotax 915s instead of the IO-540 (260hp vs 282hp).
A more conservative model.
A model with two engines at the front connected to two contra-rotating propellers in the Macchi 72 style.
And a Push Pull, DO-335 style.
I even made videos of these concepts on my YouTube channel.
But I think the only real possibility would be the most conservative model, like a little Baron.
Still going to be less efficient than the -10.
More power just means more fuel.
The 10 doesn’t suffer from a lack of horsepower at SL or at altitude.
I give you a good example. A buddy and I flew a 350nm trip together a few weeks back. Him in his Sling Tsi and me in the 10. Both solo and both light.
He was at FL160 and I was at FL140.
He’s was about 5-10 KTAS slower. Call it 7kts.
Fuel flows were more or less identical.
I put that down to the 10 being marginally cleaner than the Sling.
There’s no free lunch in engines. The one thing the Rotaxs have going for them is that they are somewhat lighter. But offsetting that is that they are significantly more complex and only get to show their true worth in the flight levels.
Are you referring to the 3 models I mentioned?
Remember that the IO-540 loses its power at altitude. While the Rotax 915 Turbochargers can maintain their power for longer at higher altitudes.
There is far more to aircraft design than a couple of ai generated pictures.
For your standard twin, you need to consider all of the additional structure required to hang the engines on the wings. How will that affect fuel tank placement? Landing gear loads? Just to name a few.
The other ideas involve relatively complex systems and structures as well.
It isn’t that the ideas aren’t possible; it is about added complexity, cost, and effort in relation to the resultant gains in performance. It would be difficult to beat the original Rv-10s all around performance with any of the new ideas.
I don’t think Vans would even entertain the thought of a twin design… unless market studies revealed a real pent up demand for the type.
