Should Vans build a twin - in the style of the Rutan Boomerang? See https://en.wikipedia.org/wiki/Rutan_Boomerang Note that design is a tractor engine, conventional tail - but the asymmetry fixes a lot of twin bad behavior. Read up on it.
No but I sure dang wish I could afford to build and operate a Velocity V-twin!
I dont think there is a prettier plane than the Velocity. I saw one at OSH a few years ago and my jaw dropped.
I'd go for something like the Wing Derringer (redux)
Jeff, I quite like where you're going with this. Nice big tail and rudder for single engine controllability. Big engines for single engine performance. It needs to be so good on one engine that the saying "second engine takes you to the scene of the crash" doesn't apply.
If we're sticking de-ice systems on this plane, then it needs big engines to keep performing when the icing gets bad too. The turbo UL520 sounds wonderful.
4 seats though, need the seats.
Would it sell? Would people build it? I'm guessing not many. Same problem as described the 6-seater thread. The plane would simply be too big and complex.
Only too big and complex if we make it so....
Against Van's devoting resources to a twin...
Maybe someone else will step up...
Given the innate complexity of having two engines, can you imagine a homebuilder NOT loading such an airplane up with gadgets and systems?
Fortunately the poll, right now, is running 10 to 1 against the concept.
Dave
If I was one of the many would-be builders out there that was watching my kit and parts shipping dates slip farther and farther, I’d be a little miffed at Vans devoting resources to anything other than current supply chain, manufacturing, and shipping issues, and I include the RV-15. I can’t imagine how that theoretical airplane isn’t years away from shipping its first empennage kit.
The practical side of me agrees with you. The dreamer on the other hand…
If Van never put a little time into dreaming and R&D then the RV fleet would consist of a few dozen RV-3s and very few of us would be enjoying this hobby. Just sayin’.
Maybe we need another poll- “which is the worse idea, a 6-seater or a twin?”
Yep, I agree with you David. I understand the Derringer had pretty good engine-out performance. Like you said, big engine, big tail, and you also need to be lightweight (read: high HP to weight ratio) to get good single engine performance. To help out on the S.E. performance, just don't load up with fuel and payload and stay light if you're worried about an engine-out scenario (mountains, night, etc.). Once you're out of the "danger zone" you can land, tank up and fly heavy, with a lower S.E. service ceiling.
That's one of the main reasons I said to have huge fuel tanks. So that even with half full "main" tanks you still have good range in the aircraft. You're going to want to have around 180 gallons total fuel capacity with this aircraft. 30 gallons in the outboard tanks (each tank) and 60 gallons in each inboard "main" tank. The UL520T typically burns 8-11 GPH so full tanks should give you about 9 hours before you're a glider. That's a LONG flight!!! With 30 gallons in each main tank, you're talking a 2 hour flight with a 45 minute reserve. The Derringer supposedly had a 184 kt cruise speed. I would expect with the more powerful engines you would be going faster but this still gives you about a 350 nm range with a 45 minute reserve. That can get you past a lot of "bad" territory.
Jim,
Good info. I agree with your dismissal of those who criticize all light twins and cite old saws. They strikes me as very similar to the misconceptions that surround tailwheel aircraft. Misconceptions which, incidentally, Van's designs have probably done more to rectify than any other aircraft in the modern era. But I digress.
A few follow up questions if I may.
You cite 90MPH as Vyse. How did you determine the zero thrust condition? Have you flown it with one caged? Under what conditions was this number determined?
What kind of Vmc testing did you do? What were the results? As I'm are you know, this is the thing that is most likely to bring a light twin to grief if not done correctly.
My real question is WHY?
I can't order a new RV-14 kit and expect to receive it in much less than a year.
With a backlog like that and orders coming in every minute why take the time to do anything except build kits all ready sold.
My business sense opinion.
Art
Ernie Gann (yeah, that Ernie Gann… Fate is the Hunter, others…) came to the home drome (Santa Paula Airport in SoCal) many years ago to visit friends on the field. He arrived in his Derringer. It was a bee-you-tifully crafted airplane.
Still going to be less efficient than the -10.Well, I'm a big fan of the RV-10.
And I designed 3 concepts about the RV-10 with two Rotax 915s instead of the IO-540 (260hp vs 282hp).
A more conservative model.
A model with two engines at the front connected to two contra-rotating propellers in the Macchi 72 style.
And a Push Pull, DO-335 style.
I even made videos of these concepts on my YouTube channel.
But I think the only real possibility would be the most conservative model, like a little Baron.
Are you referring to the 3 models I mentioned?Still going to be less efficient than the -10.
There is far more to aircraft design than a couple of ai generated pictures.Are you referring to the 3 models I mentioned?
Remember that the IO-540 loses its power at altitude. While the Rotax 915 Turbochargers can maintain their power for longer at higher altitudes.
