Hi guys.
Just throwing an issue out there for some thoughts.
Recently I've noticed the bottom of my RV is getting a streak of clean looking oil along the exit ramp and the general bottom of the belly is getting a little discoloured, brown oily look. I pulled the cowls (hate that job) and found the lower left internal cowl oily, the oil stain starting from the front cylinder (left side from pilots view). I noted some oil hanging off the induction tube bolts and the tube surface was oily as well. Pulled the induction tube off the engine after a run a& found some oil residue inside the tube, looked a bit oily up in the intake port as well. After shut down I hear what sounds like a pressure relief valve activating, gurgling sound around the front of the cowl opening. Cleaned it all up ran it and a after 2 hrs it's come back. I suspect a crack perhaps in the intake port somewhere or oil ring issues? No oil showing externally on the cylinder itself. Oil consumption seems to be slightly more than usual, about 8 hrs per Quart where is was usually 8.5-9 hrs per Quart.
Comps are good and the engine (IO360, 600 hrs) runs sweet.
Thoughts guys?
Thoughts guys?
