Danget J. You're making me want to build.
Fantastic! I bet you are having fun now for sure with those wings behind you and doing the ctr section.
I want to build. I just don't know that I know what I'm doing. I've never built anything like that before. And I kind of have struggled with the practice flap. I'm sure once I went through it I would be fine.
20180626_172836 by Jereme Carne, on Flickr
20180627_172608 by Jereme Carne, on Flickr
20180629_181719 by Jereme Carne, on Flickr
20180629_181711 by Jereme Carne, on Flickr
20180630_142417 by Jereme Carne, on Flickr
20180630_215520 by Jereme Carne, on Flickr
20180630_203452 by Jereme Carne, on FlickrGotta have a right angle drill...I got one off eBay under $100. I use it all the time. Looking good!
Jereme, we were at the same point earlier this month, but you are blowing me away. You are doing great.
Since I am behind now, I am really into your blog.
So what drill sizes do you need for right angle drilling the crotch straps?
I am working more steady now that I am watching your build, Carne. It is a great motivator. I am just trying to keep up the pace with you! Not wanting to see you flying, which would be great, and still be trying to finish my wings...haha
I guess this site is the best thing to happen to my build thus far, for many reasons!
20180701_142555 by Jereme Carne, on Flickr
20180701_142601 by Jereme Carne, on Flickr
20180702_210721 by Jereme Carne, on Flickr
20180702_210818 by Jereme Carne, on Flickr
20180702_210756 by Jereme Carne, on Flickr
pic by Jereme Carne, on Flickr
20180702_210830 by Jereme Carne, on Flickr
20180702_210844 by Jereme Carne, on Flickr
20180703_163224 by Jereme Carne, on Flickr
20180704_123044 by Jereme Carne, on Flickr
20180703_230701 by Jereme Carne, on Flickr
20180705_125921 by Jereme Carne, on Flickr
20180705_144501 by Jereme Carne, on Flickr
20180705_144518 by Jereme Carne, on Flickr
20180705_212850 by Jereme Carne, on FlickrYou're making good progress and it's looking good.
One tip: The torques seal is not supposed to be on the bolt. It's between the nut and a solid surface. See http://www.eaavideo.org/detail/video/29739769001
Thanks for the nice comment!
I disagree with this method on using torque seal. I think it is more important to know if the nut has rotated with respect to the bolt (theoretically if it's not on the threads the bolt could rotate and the nut remain stationary and you wouldn't know). If I have to remove a bolt with torque seal on it I am just going to replace it anyways.
Incredible progress once again! Keep it going.
20180717_210140 by Jereme Carne, on FlickrYou are working so fast! And looking great btw! How many hours a month do you put into this baby?
about 358 a month as far as I can tell...
20180718_112338 by Jereme Carne, on Flickr
20180718_112519 by Jereme Carne, on Flickr
20180718_114840 by Jereme Carne, on Flickr
20180718_114845 by Jereme Carne, on Flickr
20180718_114902 by Jereme Carne, on Flickr
20180718_154829 by Jereme Carne, on Flickr
20180718_211051 by Jereme Carne, on FlickrThose belly bends look pretty sweet Carne.
Quit priming everything and you will be done way sooner!
Alclad!
May I suggest while you are there, adding doublers to your armrests. Some .032 angle (sheet Bent) riveted to the inner edge and tying into to the bulkhead and vertical spar box makes a big difference in how sturdy the armrest feels and lowers the risk of bending when in use.
20180719_144713 by Jereme Carne, on Flickr
20180719_185314 by Jereme Carne, on Flickr
20180719_213213 by Jereme Carne, on Flickr
20180720_163916 by Jereme Carne, on Flickr
20180720_174930 by Jereme Carne, on Flickr
20180720_175702 by Jereme Carne, on FlickrExceptional work my brother! I have been sitting on my butt staring at the canopy frame for a month...it's still there...
20180721_125505 by Jereme Carne, on Flickr
20180721_192310 by Jereme Carne, on Flickr
20180721_192316 by Jereme Carne, on Flickr
20180723_140305 by Jereme Carne, on Flickr
20180723_181241 by Jereme Carne, on Flickr
20180723_184006 by Jereme Carne, on Flickr...it's nice to be drilling things again...
Come on over to Oregon and twist some cobalt in the RV-6 if you have an "itch to drill"!
Progress looks good, and nice job on the conical bends. I'm still trying to decide the best way to hide my small stop-drilled cracks (on both sides)
20180725_142422 by Jereme Carne, on Flickr
20180725_120757 by Jereme Carne, on Flickr
20180726_120741 by Jereme Carne, on Flickr
20180726_120946 by Jereme Carne, on Flickr
20180726_123641 by Jereme Carne, on FlickrI would say put it under both your feet, and add the fire barrier to boot!
"Firemax" Aircraft Spruce
20180727_152802 by Jereme Carne, on Flickr
20180727_152818 by Jereme Carne, on Flickr
20180727_211231 by Jereme Carne, on Flickr
20180727_211843 by Jereme Carne, on FlickrYour progess is awesome! Keep it going while you have the momentum. Also Thanks for mentioning Nova drills. See they're $120. Did you get the 4000 rpm? Did you get the keyless chuck?
I followed Dan's advice as well, to a degree, and determined that I am going to put firemax on the inside of the firewall and on the bottom skin inside under the second floor skin I am going to add.
Heat is what we are trying to keep out for the most part I believe, and fire of course ultimately.
I am going to call you "The Machine" from now on.
Because that is what you are, a Machine!
You primed all that and riveted it all in a few days!
