I've been planning a transatlantic trip to Ireland since I started building the -10. A tribute of sorts to the Irish who came before me to this great land in the knowledge that they would never return to the Emerald Isle. Anyways, here's my long-range tank installation. I designed the tank to hold 40 gallons and be easily installed and removed by one person. Fuel is plumbed into the 3rd port on the factory fuel valve. There's a small sump for the gravity feed, a finger strainer and an in-line fuel filter. A no-drip quick disconnect snaps into a fitting installed in the tunnel inside the area normally covered by the flap cover. The vent is similarly located through the tunnel and out the bottom of the fuse. A resistive sender connects to a spare channel the G3X and shows fuel level on the engine page alongside the main tanks.
