SB 18-02-02 Potential cracking in the horizontal stabilator front spar
Doug
Can you describe or explain your " washer wrench"?
Cleaveland Aircraft Tool $37
I have had some success putting a magnet on the bolt head after partial insertion and getting the washer to stay put on the bolt shank. This job needs all the tricks!
I installed the stabilator today. After glueing the washers with super glue I embedded the washers with epoxy. No problem with knocking off the washers. Still took some time to insert the bolts.
I did not want the HS-01231C on top of the skin of the Stabilator.
I am doing a vinyl wrap and I have all CS4-X Rivets to keep the vinyl as flat as possible.
This is not a recommendation
Also this is not a cracked Spar repair.
See More
http://joesrv12.com/Builder Log/SB_18_02_02_01.htm
Joe Dallas
The full sized doubler was not designed specifically to a repair stabilators that were found to have cracks.
It was specifically designed based on doing an FEA (finite element analysis using a computer model), and analyzing the loads seen in the hinge joint / fwd spar.
My recommendation to other builders is that they install the parts as designed.
There will be no problem applying vinyl over the doubler (if that is your plan) after some experience is gained working with the wrap material.
My View
Scott
I made it perfectly clear that this is not a recommendation.
We have different views on what a patch looks like.
I can install vinyl over LP4 Rivets and with a lot of finger time they look ok.
I think it looks better over CS4 Rivets.
And Vinyl over a Patch Still Looks Like A Patch in my view.
We also designed a lot of things before Computers were invented.
I sure if you ran a computer analysis on my design it would stack up pretty well with Van's and a lot better than Vans original design, and with only few problems worked pretty well.
However that is not the point, I am building EAB so I can have the Aircraft I want not a standard RV12 which is a well built Aircraft.
It is a good thing that Van used his own ideas to built all the great Aircraft in his line.
Thanks for your View
Not a patch. Patches are for bicycle tires. Aircraft don't do "patches". Correct term is doubler. Look at the bottom of your fuselage and you will see a number of doubler plates in high stress locations. Doublers are used to distribute load safely into the surrounding skin...
This is Silly
http://hhh.gavilan.edu/hspenner/iLe...ural Repair/AircraftMetalStructuralRepair.pdf
See page 140
The doubler is not a patch there in no damage under it.
It is just a term
My View It is a Patch
