I bet Eric at Perhelion designs could make a high voltage idiot light.
This one looks promising, sorry if it continues thread drift.
http://vi.raptor.ebaydesc.com/ws/eB...y=79846&pm=1&ds=0&t=1508951838798&cspheader=1.
Triggers a red/green flash at >15.2 V
$17.
Integrated LED Battery charge / level indicator
12v Model
Other models and voltages also available! See our EBAY Store
Good for any 12v Lead Acid / fiber mat / gel battery where you want to monitor charging and voltage levels between the ranges specified in the tables below.
Hundreds of voltage monitors sold! CHECK OUR FEEDBACK!
Buyers comments for our range of monitors :
· Must be good as this is my second one. 1 for the bike & 1 for the microlight.
· Next day delivery, fantastic service.
· Good service. Communication Excellent. Good product. Informative Instructions
· great little gadget
· Very fast delivery. Very Helpful. Nice & compact - would recommend
· Good company, honest, fast response. Good to do business with.
· excellent Item , really well made , good communication recommended
· **** fine bit of kit ! Thank you.
· super fast delivery working perfectly - recommended Thanks
· Excellent product, comprehensive instructions, fitted and working no problems
Indicates Undercharging AND overcharging. Protect your electrics!
Check the specification!...............
Integrated tri colour (Red, Green, Yellow) 10mm LED and microprocessor assembly
Rubber Wrapped for waterproofing and shock resistance.
Single 14mm hole required for mounting. Just 29mm behind control panel.
10mm tri-colour LED indication of your battery level or charging state
Voltage : 12v DC dependent on model. See our EBAY store for other types and ranges
Unit will operate down to 3.7v.
Power Consumption : 10mA nominal
Internally PTC fused (self resetting) - dont risk your system wiring with an unfused unit!
Reverse voltage protected. Try connecting it up backwards, you cant break it!
Internal 'watchdog' makes sure the unit can never crash and is always reliable
RC integrated voltage measurement input
Multiple oversampling - unit takes 10+ readings to obtain greatest accuracy.
Built in hysteresis to prevent 'strobing LED' when unit is at changeover point.
Display LED updates 10 times each and every second.
Can be set at installation to operate over one of TWO ranges
Supplied with fitted connection leads
Supplied with comprehensive instructions
The Details...............
Its annoying when your battery goes flat without warning. Some vehicles, such as older motorcycles, dont even warn you if your alternator has failed. You run on battery until the lights get dim, engine misfires and everything stops. With this neat little device, you get a nice clear warning that something is wrong. On the other hand, you might just want to know how much juice is left in a battery powering a system that has no charging facility.
This versatile unit can be used wherever you have a 12v lead-acid, fibre mat, or gel technology battery or charging system. Perhaps your bike, car, caravan, camper or boat, or that battery you have to power the lights in your shed can go flat on you without warning, or you would like some idea of how much juice you have left?
Our battery / charge monitor device is FLEXIBLE so you can use it to tell you if your battery is charging (working alternator!), or, if you want a simple way of finding out how much is left in your battery, the tri-colour LED will illuminate in different colours, and even flash to tell you the 'current' situation. Simply set the link on the rear of the unit to set operating mode at installation time.
The large 10mm green/red/yellow/flashing LED is built into a black mounting bezel, with just two wires you connect into your electrical system. One to battery positive, one to negative. We couldnt have made it simpler.
The tables below show the operating range of the unit, depending on the mode set by pulling off or putting back a removable link on the rear of the device :
The 10mm LED indicator will signal at the following levels :
Battery Charging Indicator Mode (No Link Fitted)
Version
Red / Green Flsh
green
Yellow
Yell Flash
Red
Red Flsh
12v DC
> 15.2v
13.2v
11.8v
11.5v
11.2v
<11.2v
Battery Level Indicator Mode (Link Fitted)
Version
green
Yellow
Yell Flash
Yell Fast Flsh
Red
Red Flsh
Red Fast Flsh
12v DC
12.1v
11.8v
11.5v
11.2v
11.0v
10.7v
<10.7v
