AlexPeterson
Greetings,
After 15 years and 1540+ hours flight time, in October I started on an upgrade which will include complete modification to the electrical system as well as new avionics. This picture, at first glance, appears to one of an airplane wreck:
Unlike during the initial build of the plane, where I mostly worked on one system/component at a time, this project requires a lot of simultaneous sub-projects at once, hence the huge mess...
The electrical system changes include: battery moved to forward of the firewall, solenoids ditto, fuse and grounding blocks moved from near the firewall (inside) to between the panel and sub-panel.
One finds that maintaining an RV for 15 years greatly increases one's wisdom about what to place where... A design goal for this project has been to eliminate the need to climb under the panel for most things. I'll post pictures as I progress.
(Entropy: state of disorder of things)
