Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
09-02-2022, 11:05 AM
Torque Seal solvent ?
Is there a solvent that will remove torque seal ?
Let's say someone torqued a few bolts to the wrong value and needs to redo them. Asking for a friend.
09-02-2022, 11:39 AM
Just me
I always found the torque seal is brittle enough to where it will poop off with a little coaxing. If you must, one can use a pair for dikes (diagonal cutters) to remove the torque seal. YMMV
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2023, worth every penny
RV9A- Status:
98% done, 2% left to go
To Go: wing mounting, engine baffles, wing tips, move to airport
www.pilotjohnsrv9.blogspot.com
09-02-2022, 11:42 AM
I break it or use a brass brush to erode it.
Laquer thinner will work to re-dissolve it, to your question. I inject some in the tubes to keep liquid.
Bill
RV-7
09-02-2022, 12:31 PM
Were the bolts over torqued or under torqued?
Terry Edwards
RV-9A (Fuselage)
2022/2023 VAF Contribution Sent
09-02-2022, 12:36 PM
They were only under torqued.
09-02-2022, 02:51 PM
You can use an exacto knife to get rid of most of the torque seal and then I use lacquer thinner to clean up any of the remaining.
Ray Tonks
2022 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
Sensenich Composite 3 Blade Propeller
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
09-02-2022, 02:58 PM
Remind your friend not to put the torque-seal on the *threads*, also.
2022 Dues paid!
09-02-2022, 07:30 PM
Also clean the area. Torque seal might look unbroken only to be rotating with the nut and “sliding” along her surface as it lost it adhesion. Belt and suspenders would be permanent marker as well, that will catch a rotating bolt/nut assembly.
09-03-2022, 02:05 AM
put a wrench on it
Some guys on this forum far smarter and better-looking than me reminded me recently that torque seal can't be relied upon to confirm a bolt is still tight or has not moved. In their immortal words, put a wrench on every nut and bolt you can when you are doing an inspection.
09-03-2022, 04:41 AM
The term torque seal is really a misnomer. Better term is slippage indicator. And like any warning light, it is not a 100% guarantee that no slippage has occurred.
Philip
RV-6A - flying 1000+ hours
Donated to VAF yearly since 2007. Why? Because it is worth every penny and more.
There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. —MARK TWAIN
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
