Old 06-03-2021, 02:02 PM
mtnflyr mtnflyr is offline
Default Need Help Analyzing Borescope Images - Leaking Exhaust Valve on Lycoming O-360-A2D
Fired up the O-360 in our RV-6A last week and it ran rough, with EGT in the #3 cylinder failing to come up. Shut down the engine and pulled the plugs - they looked find. Then, a compression test and we could clearly hear air entering the exhaust system. Bought an inexpensive borescope, and the following are video clips and images of the exhaust valve in question. I've not analyzed borescope imagery before and could use some help with what these show. I'm reading everything I can find on leaky exhaust valves and ordered a valve guide reamer from McFarlane in case this is a stuck valve. I'm also looking into lapping the valve in place since it appears to me (remember I've never done this before) that there is significant pitting on the valve and the seat.
Help!
youtu.be/D9OgOrHm-xg
youtu.be/5etTaez_qoA
[IMG]www.dropbox.com/s/ntu56pw54kzi1g7/IMG_0001.JPG?raw=1[/IMG]
[IMG]www.dropbox.com/s/04hggsgiwcyjzho/IMG_0002.JPG?raw=1[/IMG]
[IMG]www.dropbox.com/s/gozttcn6fbdiqt5/IMG_0003.JPG?raw=1[/IMG]
[IMG]www.dropbox.com/s/qh9ltzakxmlthhr/IMG_0004.JPG?raw=1[/IMG]
[IMG]www.dropbox.com/s/cie11t1huskow5o/IMG_0007.JPG?raw=1[/IMG]
[IMG]www.dropbox.com/s/prm2n9q3n0ovueu/IMG_0009.JPG?raw=1[/IMG]
Old 06-03-2021, 02:22 PM
rocketbob's Avatar
I've had mixed success with in-situ valve lapping. Sometimes its just better to pull the cylinder and have a new guide installed and clean up the valve and the seat. You will have to check the dry tappet clearance if this is done when you put the rockers and pushrods back on.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 06-03-2021, 02:25 PM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Ok, my 2ct...
This could basically mean 2 things: either a stuck valve, or a leak around the seat... which doesn’t automatically result in a non firing cylinder.
Looking at vids & pics, the valve can be rotated easily, thereby discounting the guide/stuck valve theory.
Valve seat, I don’t see a specific spot, which would show as a black trail, on either the seat nor the seat. The valve burn image shows a quite regular pattern of an engine with a couple of hundred hours, not fully concentric, but regular pizza.
So my quick glance doesn’t reveal any obvious defect. Stupid question, is the «*air entering the exhaust*» happening on cylinder #3?
What were the values of the compressions?
Life's short... Enjoy!
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 06-03-2021, 02:53 PM
BH1166 BH1166 is offline
Default Looks good
Agree with Dan, looks great to me. Compression test, hot or cold? Numbers? Running rough, did you throttle up and try to clear? Any chance your compression testing was flawed.
Butch
RV6A Purchased N72TX
Old 06-03-2021, 03:41 PM
YYC650 YYC650 is offline
Nice images. What borescope did you use?
RV-7a @ CYBW
2020 dues paid
Old 06-03-2021, 07:45 PM
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Not sure I'd recommend it. The first one I received wouldn't hold a charge. I returned it to Amazon and they sent me a new borescope and this one won't charge past halfway and runs out of juice in around 30 minutes. It's also a chore to get it oriented correctly - bend, install, pull it out, bend it again, hold your tongue just so . . . . If I return this borescope, I think I'll go with one of the Vividia products. The VA-400 is recommended by Mike Busch and it was after watching his AOPA presentation on exhaust valves that I bought this unit. I think the ability to bend the head from outside the cylinder would make this job a whole lot easier.
Old 06-03-2021, 07:55 PM
Ran the engine long enough for the EGTs to come up and #3 was hardly rising at all. Very rough. Compression test the next day, cold. 30/80 in #3. Very obvious air sound in the exhaust pipe. Definitely leaking.
I'd been getting a "pop, pop, pop" at full throttle on climb out for a couple of flights earlier, and that concerned me. Running a bit rough, but everything smoothed out once she warmed up.
Funny thing is, before that the engine had been running the smoothest it has since we bought the airplane and the compression tests were the highest and most consistent ever at this year's annual done last month (78/80).
Sent the pics to a cylinder shop and they said the pitting was consistent with a mid/high time engine. They recommended trying to lap in place and when that didn't work, pull the jug and send it to them. They said to expect the lapping in place wouldn't fix the issue.
Old 06-03-2021, 07:57 PM
akarmy's Avatar
akarmy akarmy is offline
I've lapped a number of valves in place on my 0-360 which on average raised each cyl about 15lbs. I did this over a 2 year period but it would always start leaking again. We pulled the Cyl's and found very worn valve guides on the exhaust valves.
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2020 Paid
Old 06-03-2021, 08:02 PM
I think that's the next step for this valve. Worth a try as it doesn't cost me more than the price of some lapping compound. Couple of questions:
- What lapping compound did you use?
- I'm worried about getting the grit on the cylinder walls and the valve stem. How did you get things cleaned up in between changing grits and when you were all done?
- How hard do you pull on the valve stem? Is this just a light pull, or lots of pressure?
- Thinking of making a jig to hold my dial indicator to do a wobble test. Did you do that?
Old 06-03-2021, 08:47 PM
akarmy's Avatar
I just used permatex valve lapping compound from the auto parts store. 2 grits
We sprayed the valve with brake cleaner through the spark plug hole with the lower plug out to drain the excess out.
Pull as hard as you can while spinning it.
I didn't do the wobble test (looks like I should have as that's where mine failed in the end)
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2020 Paid
