Old 11-18-2019, 12:37 AM
sinflrobot sinflrobot is offline
Default Rudder Damage from Wind
Some wind got a hold of my rudder during the last front that came through. Overall it still appears straight, but I am a bit concerned about what to do with two small tears in the trailing edge. It doesn't look horrible, but I was wondering what more experienced folks think the best way to repair this is.
(Its an RV6A, so it doesn't have the riveted in trailing edge wedge.)
Jeremy
Austin, TX / Telluride, CO
RV-6A-- N900KH
Old 11-18-2019, 01:30 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default rebuild
I hate to be "that guy", but a really bad outcome started with a post like this a couple of years ago. Check with the factory, but if it were me, I'd just rebuild it.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 11-18-2019, 02:53 AM
KayS KayS is offline
Jeremey, are the damaged spots on top of the rudder and right at the trim sheet cracks?
Old 11-18-2019, 06:31 AM
BillL BillL is offline
Default Build a new one.
This airplane is grounded!! Looking at the TE, it looks like a tear right in the zone where separations have occurred, this definitely needs a new rudder built, very serious.
Call Vans for just how far you go, then get transferred to "order" a new kit. Maybe they will say the spar a ribs are OK. Also check the VS for any damage on the front spar connection to the HS spar.
Bill
RV-7
Last edited by BillL : 11-18-2019 at 06:38 AM. Reason: emphasis on grounding the plane.
Old 11-18-2019, 06:45 AM
DanH's Avatar
DanH DanH is offline
Grounded +1
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-18-2019, 07:34 AM
wilddog wilddog is offline
Default F
Check your elevator for damage where it contacted the rudder TE. Agree with other posters, new skin at minimum.
Old 11-18-2019, 08:15 AM
gmkonrad's Avatar
gmkonrad gmkonrad is offline
Default rudder
Check your PM's.
Gary
Gary
RV-7 FLYING
N319GK
Old 11-18-2019, 08:44 AM
Im having a hard time figuring out how the rudder got damaged along the trailing edge. I didnt think it was possible to contact the elevator at that point.
What else did it hit?
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
Old 11-18-2019, 09:22 AM
Sam Buchanan's Avatar
been here awhile
My thoughts exactly, the long scratch is where the elevator would contact the rudder. Has the rudder been flexed sufficiently to crack the trailing edge?
Sam Buchanan
RV-6
Old 11-18-2019, 09:32 AM
rvbuilder2002's Avatar
Inertia
The entire mass of the rudder is moving rapidly to one side but then is instantaneously stopped by the rudder stop at one end.
The remaining mass of the rudder attempts to stay in motion which puts a twist load on the rudder. This is also how the indentations from the trailing edge of the elevators occur, even though there was likely clearance between the rudder and elevators at full travel.
The issue is amplified even more if it is a rudder with a counter balance weight.
It looks like this one might be a later rudder with the counter balance. If so, it would be an easy repair because it would essentially involve removing the skin and installing a new pre-punched RV-8 rudder skin.
If it is an early vintage (short) rudder, removing the skin and match drilling a new one would still be the simplest repair because the hinge points were established by the builder based on dimensions. It would be far easier to reuse the same sub-structure frame than making a new one that would properly fit the vertical stab.
I agree that the rudder should be replaced before further flight.
If it needs to be ferried, a light weight bent patch could be made and installed with blind rivets. It would be prudent to reduce speed slightly for the ferry flight.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
