Go Back   VAF Forums > Education > Instrument Flight Rules
Old 11-07-2019, 07:43 AM
uk_figs's Avatar
uk_figs uk_figs is offline
Default Correct terminology with ATC or Tower
When under ATC control and changing frequency what is the current correct terminology to announce your presence on the new frequency, I have recently read that "with you" is not correct and "up" is also not correct.
Tks
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 11-07-2019, 08:03 AM
Toobuilder's Avatar
If "with you" is now wrong, I have a 20 year habit to try break.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 11-07-2019, 08:09 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default freq change - check the AIM
The AIM says to give them something useful, and avoid fluff.
Austin approach - n12345 - 3500 ft
https://airresearch.com/Pilots/AIM-0...5/aim0503.html
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 11-07-2019, 08:16 AM
Tailwind/RVGuy Tailwind/RVGuy is offline
+1 On a "hand off" that is exactly what I use: "Denver Center- N12345 - 8500 ft" Tells them exactly what they need. They were expecting you and they just need to know you are there and what altitude you show.
Keith in Lacrosse WI area
Finished Wittman Tailwind in 2016
Flew RV9A and RV6a while building
lurking for years but now paid
Old 11-07-2019, 08:21 AM
airguy's Avatar
airguy airguy is offline
Same. On a "switch to my frequency" I'll switch first then transmit "N12345 with you on xx.xx"
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 11-07-2019, 08:31 AM
rocketman1988 rocketman1988 is offline
Default Phraseology
You can look up the proper phraseology here:
https://www.faasafety.gov/gslac/ALC/....aspx?id=17272
and a summarized version here:
http://wiki.flightgear.org/ATC_phras...ise.2C_descent
One of the most annoying habits I see, on a day to day basis, is people not being concise in their communications. An example frequency change would be:
"Uh...Houston center, experimental N12345...we are a Van's RV-8 and um, we are 25 miles North, no I mean South of XYZ VOR and we are at 4,000 feet and climbing to 6,500 feet heading 240 degrees, no wait 241 degrees, going to KABC airport checking on with you...Over."
When you really only need,
Houston Center, N12345, 4,000 climbing to 6,500."
Long winded communication just ties up the frequency...
Bob
Aerospace Engineer '88
RV-10
N464RL
Dues+ Paid 2020,...Thanks DR+
Old 11-07-2019, 08:55 AM
Hwood Hwood is offline
I usually like to preface a transmission to ATC with...."Hello" (Technique only)
After all, they are human too....
Hwood
Finishing up an -8
Exempt but paid
Old 11-07-2019, 09:28 AM
KleensRV6's Avatar
KleensRV6 KleensRV6 is offline
Default It Depends
One of my personal upsets are pilots failure to listen on the new frequency before reporting in. If a controller is giving another aircraft control instructions they really don?t want to hear anyone?s else?s ums and awhs until they know United 680 has visual with the traffic they have pointed out to them. My rule of thumb is to give the frequency at least 5 seconds before making my initial call. YMMV
Jailbird/CW Kleen
RV6 KGIF
Old 11-07-2019, 05:53 PM
flyinga flyinga is offline
Several surveys with controllers show that they don't particularly like "with you."
Also, bad form to say "four thousand for one four thousand." Should say "four thousand climbing one four thousand." The "for" adds confusion.
YMMV
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 11-07-2019, 06:56 PM
crabandy crabandy is offline
Kieth is correct, Greg in the following post is also correct for the most precise with the least syllables when the frequency is hopping. “With you,” “Hello” etc is also fine within the context of the situation and how busy the frequency is, I like to include a “Wecome” with a check-on when time allows.
Saying “with you” or “up” is implied, kinda like “N1234 if you hear center ident” vs “N1234 ident.”
About halfway into training a newbie controller we’ll charge them a nickel for every wasted syllable during a day of training. It would pay for Lunch, gas, beer and then some!
Always extra points if the pilot has a proper British accent....
RV 7 500 hours and counting
20 donation done
