Old 02-13-2018, 10:09 AM
Special Delivery's Avatar
Special Delivery Special Delivery is offline
Default Drill Bit Organization - I'll show you mine if you'll show me yours
The photo below was semi-staged, but it's not far from what I often find on my workbench.
Seeing that our community is in constant pursuit of a 'better mouse trap', the custom wood tail lift, Randy Richmond's tool box, and Steve Melton's 3D designs immediately come to mind, I'd like to see what other have done to solve the problem of keeping various bits, cages, and the like organized.
Thanks in advance from a height and organizationally challenged builder.
R. E. "Ernie" Butcher
Friends of the RV-1/Eagle's Nest Projects
"Mentors build the student...
Students build the airplane." -Glen Salmon
Dedicated to the historical preservation of the RV-1 Aircraft
and organized for the purposes of promoting, supporting,
fostering, and engaging in aviation and aerospace education.
www.RV-1.org
www.EaglesNestProjects.org
Old 02-13-2018, 10:31 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I have a box that looks almost exactly like that Ernie .... well, actually, it’s not a box, its an entire drawer! I do, of course, have a couple of indexed drill boxes in the drawer, and most of the slots are full, so that’s where I go for a specific numbered bit. But I have lots and lots of unorganized 40,30,19,10, etc....bits of various lengths, and only experince tells me what to grab.
Yup - I’d like to see what others do as well!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-13-2018, 10:59 AM
Paul, I suspect we're not the only ones challenged in this area. At the other end of the spectrum we occupy is of course, Jay Pratt at RV-Central. I didn't realize when Jay agreed to host the 'rebuild' of the RV-1, that his shop has virtually every aircraft tool known to man; and that literally blindfolded, he can put his hand on a #11 jobber bit, a 3/8" combination wrench, or a #30 120* countersink. Pretty impressive organization and his shop was certainly a Godsend in the RV-1 project.
www.RV-1.org
Old 02-13-2018, 11:19 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default Uh-oh...
I would probably pass out if I saw such an arrangement!
My arrangement uses drawers, and the 'usual suspect' plastic bins and large paper cups. New number drill bits are hidden: I can't find 'em to scatter 'em around.
Aside from that, I have a couple un-opened drill indexes that are pristine...for a while...
Now, I will admit that I put out a cushy section of paper towel on the bench to comfort the assortment of bits, de-burring tools, and rivet sets that remain on the bench until the project is finished...which appears to be years in this case, not weeks or months...so I refresh the paper towel from time to time...I might even upgrade to the BLUE towels at some point!
I did arrange my measuring tools this morning. Managed to find 'em ALL!
What really ticks me off is the new Harbor Freight store 2 miles away. Not quite on a first name basis...
Best,
Mark
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
Old 02-13-2018, 11:21 AM
gasman gasman is offline
Give more consideration to that index card. You will continue to use it way after you stop using your drill bits.
VAF #897 Warren Moretti
2021 =VAF= Dues PAID
Old 02-13-2018, 11:32 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
Just buy one of these and keep it handy. It also tells you what sizes you need for tapping and clearances above the usual RV ones.
Available at any good hardware store and better than a piece of paper.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-13-2018, 11:52 AM
stevemcgirr stevemcgirr is offline
Default my method
I'm the last person anyone would ask for advice on shop organization, but I do have a simple drill bit organization tip.
Get a block of wood. (I used a 1 inch thick piece of hardwood). Trace a grid. Make it about 3 to 4 drill bits to a row and as many columns as your wood length permits: you want to be able to grab the bits, so not too close. One at a time, chuck each bit that you want to store and drill an approximately 1/2 inch deep hole. Since you are using the very bit that you will be storing, it will fit perfectly, but I marked the holes as well for ID.
I find that by making small blocks that hold the bits I need most often (2x#40, 2x#30, a #19, a #12, a #10, etc), I can put my hand on a bit more quickly. Having the holes match the bits assists in identifying. I used a drill press to keep the holes perpendicular.
I know this is simple and obvious, but it works for me.
Steve McGirr
RV7 N1991M
First Flight: May 18, 2013
Old 02-13-2018, 12:09 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default drill bits
These are not mine, but they look like this:
Except #30 and #40 I have a special place for them since I love them so much.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 02-13-2018, 12:35 PM
Gil, You missed my point.
Old 02-13-2018, 12:37 PM
az_gila's Avatar
Thumbs up
Nah.... my reply was that a metal list of drill sizes is better than a paper list, and you get a "checker" thrown in too...
Gil Alexander
