Keep VAF
Going
06-12-2012, 09:15 AM
Thats just COOL, thanks Dan!
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
01-20-2013, 10:34 AM
Supplier and shelf life of 3M Fire Barrier 2000 Plus
Where did you purchase your 3M Fire Barrier 2000 Plus? The 3M pdf says the effective life is 12 months after manufacture. Anyone have any insight on this shelf life?
IHN,
2020 Dues Paid
Robby Knox
THEM: Why do you always carry a knife?
ME: I can't open a bag of chips with my Glock!
01-20-2013, 10:52 AM
CharlieWaffles - But you can call me " Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
01-20-2013, 11:01 AM
Try Home Depot, Lowes, or whatever bigbox construction store is local. Also, good electrical supply houses usually stock it, or something similar.
Charlie
02-11-2017, 08:48 PM
Deleted deleted
John Bright, RV-6A, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDS EFI EM-5-F
Z101 as a template, links
03-08-2017, 08:51 PM
Any thoughts to using Vans heat reflecting material over the fiberfrax as a low cost substitution of stainless steel?
https://www.vansaircraft.com/cgi-bin...cowl_protector
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2020
03-09-2017, 05:38 AM
As stated previously, the big box stores only seem to carry latex based intumescent caulk, not FireBarrier 2000 silicone. Not at all what you want.
Any sort of shiny metal film over fiberfrax will reduce heat engine transmitted to the cabin during normal flight. An aluminum foil, however, would be totally useless as a fire barrier. Seconds after application of the standard 5" x 5" 2000F hotspot, the aluminum will evaporate. Then the binder will burn out of the fiberfrax, and airflow will blow the loose fiber off the firewall.
Dan Horton
RV-8 SS
Barrett IO-390
03-09-2017, 07:57 AM
The link you provided does not specify what type of metal the heat reflecting material is.
03-09-2017, 08:39 AM
Yeah the Vans website does not say what it's made of. It's intended for under the cowl. I just saw how cheap it is and was wondering if it could work in this application. Dan's assumption that it aluminum is probably accurate due to it low cost.
Rob Lasater
Paid Dec 2020
03-09-2017, 09:28 AM
It's aluminum. Works great over fiberfrax to protect fiberglass and paint.
Dan Horton
RV-8 SS
Barrett IO-390
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
