VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Model Specific > RV-9/9A
  #21
Old 11-11-2022, 05:08 PM
MacCool's Avatar
MacCool MacCool is offline
In an area where winter temps are typically 30s - 40s (F°), the Twin Hornet 22 might work fine. I can't attest...I have more robust needs, and my cowl and intakes are not particularly amenable to that configuration. I can endorse the quality of construction by that company as I do use a Hornet 45 cockpit heater and like it a lot.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
Dual Pmags
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
Old 11-11-2022, 06:27 PM
mbuto mbuto is offline
What is different about your cowl that would make this heater a poor choice for your plane? All RV's are the same?
Mid 20's to mid 40's (F) would be of concern here.
Old 11-11-2022, 07:44 PM
MacCool's Avatar
All RV's are similar. I have a carbon fiber-capped plenum which leaves no room to shove a pair of Hornet 22's in there. I have zero interest in de-cowling to apply pre-heat and find that a Reiff XP sump heater and cylinder bands perform that pre-heat function much more efficiently in my particular local climate. All I have to do is remember to plug it in to the cell-phone siwtch before I leave the hangar...just another step in addition to plugging in the dehydrator and the battery maintainer. My Turbo XP is entirely plug-and-play, and all I have to do is pull up the app and turn it on remotely about 4-5 hours in advance from wherever in the world I happen to be.
Dual Pmags
IFR equipped
