Old 01-17-2020, 03:23 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Originally Posted by andreskatz View Post
i have a similar panel with a g3x touch and garmin gtn 650 like yours, then how do you become adsb out compliant with such equipment? i called stein air and they say that it should be but i tested it on the ground and got no signal
any help appreciated
andres rv8
I forgot to mention that I have a GTX 345 transponder...
PM Sent - happy to help you work through the config changes
Brian Decker
RV-7 (Flying)
Old 02-02-2020, 11:41 PM
smt6 smt6 is offline
Any chance on adding a “Hours on oil” meter?
Old 02-02-2020, 11:55 PM
JTJones's Avatar
JTJones JTJones is offline
Default How about this...
This applies to the GTNs but there isn?t (I don?t think) a GTN Wish List. But I?ll submit here for the G3X and GTN that in my experience, 90% of the time I push the Direct To Button it is to go to a fix that is in my flight plan. After all, ATC usually clears you to a fix that is in your flight plan. However, after pushing the Direct button I then have to select the Flight Plan Tab to get to the fix I would like to go direct to. I suggest that when selecting the Direct To Button, the default tab is the Flight Plan Tab. Any one agree?
Jeffrey T Jones
RV-14 N588TJ Completed
First Flight July 10, 2018
Flight testing completed August 14, 2018
2022 VAF dues paid plus beer money😜
Old 02-03-2020, 06:41 AM
F1 Rocket F1 Rocket is offline
Default Simpler display view options?
I?m on the very steep learning curve on my recently installed G3X panel. This is an upgrade from my original Dynon D100 based panel. The hardest thing I?m finding to adjust to is the incredible amount of info available on the G3X PFD. This is great but...I?m having a hard time seeing the basics. My old D100 was easier to read.
Danny
F1 Rocket #25
N14ZM "Dreamer"
Melboring, FL
Old 02-04-2020, 05:21 PM
kearney kearney is offline
Default G3X MFD Reversion
Hi
Grounding pin 25 on the MFD d-sub connection causes reversion (duplication) of PFD flight instrumentation onto the MFD. Can this be done from the G3X without adding a switch. I have a 2 G3X panel with screens off center to the left. For the co-pilot, the reversionary mode would be more better as it provides a better view of flight instruments.
Regards
Les
RV10 C-GCWZ sold
RV10 C-GROK flying
Old 02-04-2020, 06:06 PM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
Les,
The short answer is yes. I have the same situation and I have a soft key in the upper left of my MFD to switch it to PFD. PFD will then display on both screens. There?s a setting- don?t ask me how I did it though....
Originally Posted by kearney View Post
Hi
Regards
Les
RV10 C-GCWZ sold
RV10 C-GROK flying
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019, 2020, 2021, 2022 donor and happy to do it.
Old 02-04-2020, 06:55 PM
rjtjrt rjtjrt is offline
Originally Posted by Planecrazy232 View Post
Les,
I would love to know how to do this setting.
Old 02-04-2020, 07:47 PM
Check out the pilot guide page 41. It says GDU 45x or GDU 470 for this feature. I do have a 470.
Anthony
Old 02-05-2020, 06:00 PM
Thanks Anthony
..Les
Old 02-05-2020, 07:00 PM
Anthony.
Very helpful. Thanks.
