Old 08-29-2021, 05:13 AM
JFCRV12 JFCRV12 is offline
Default Washer?
Stupid question: I purchased the new screws. Do I also use a nylon washer with them or just the screw?
2021 Dues Paid!
Old 08-29-2021, 08:08 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by jrock836 View Post
I finally remembered to take some photos of my issues.. The photo where the spinner is visible shows the fine crack in the cowling..
That's a paint problem. Do you know the brand and product line of the primer and/or primer surfacer under that red paint?
FWIW, I've run AN526's and nylon washers over 1000 hours now, and this -8 cowl is loaded a lot higher than a 12. All the screw areas still look like new.
Click image for larger version
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-29-2021, 08:12 AM
jcarne's Avatar
jcarne jcarne is offline
Dan how is your spinner attached? I don't see any screws. Camera tricks?
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 08-29-2021, 09:16 AM
F1R F1R is offline
Default Screwless Spinner
Im not sure if it can be searched with the new format forum, but it has been posted with great detail in photos and text.
Dr Glass Innovation did a nice job again.
Old 08-29-2021, 10:10 AM
DanH's Avatar
Best answer is credited to Mel..."Speed!"
However, reality is found here:
https://vansairforce.net/community/s...ad.php?t=36101
https://vansairforce.net/community/s...04&postcount=5
https://vansairforce.net/community/s...31&postcount=7
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-29-2021, 01:17 PM
jcarne's Avatar
Well hot dog, never seen that before! Thanks for the links. Something to think about for my next build.
P.S. yours looks awesome
Jereme Carne
PPL
Old 08-29-2021, 03:32 PM
rvbuilder2002's Avatar
Not a direct comparison though….
The RV’s-12 cowl is made from wet layup glass / epoxy, and it is also much thinner.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 08-29-2021, 03:33 PM
The current plans spec AN525 and a nylon washer.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 09-01-2021, 12:03 PM
Charlie12 Charlie12 is offline
Default screw spec per KAI
I posted this a couple days ago in another thread. Just trying to get the facts clear in my head. The current KAI for RV-12 posted on Van's website, p. 38-07, still says AN526C for the front six screws on the upper cowling. The comparable RV-12iS KAI, p. 37iS/U-12, says AN525. The factory notification process has never sent me any recommendation to change the screws on the RV-12. AN525 makes sense, and I will switch them next time I have the cowling off.
RV-12 #120768, first flight Sept. 2016
344 hrs as of 8/27/2021
Old 09-01-2021, 12:59 PM
I saw you post, and posted an answer in that thread.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
