  #341
Old 07-06-2021, 05:05 PM
seagull seagull is offline
I upgraded my grips to Tosten CS-8 grips. I did it during the conditional inspection so I had everything open saving some time. I estimate about 2 days additional work for the mechanical and electrical rewiring.
This grip added selection of radio channels, flip flop, elevator trim, and autopilot, plus trigger PTT. My OEM trim on the dash was changed to a on/off switch that can disable the right seat stick grip functions. The OEM autopilot CWS button was changed to a toggle for the fuel pump, (it stays on during all phases of flight).
Name:	CS-8 installed.jpg
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 09-15-2021, 09:44 AM
Amadeus Amadeus is offline
Default Fuses?
Has anyone modified from fuses to breakers after certification?
Purchased N112DR E-LSA flying with 28.2 hours - Thank you David (CraftingN112DR) for putting your skills, knowledge and attention to detail in this RV-12iS!
Dropped at paint shop this morning (July 15, 2021)
Picked up from paint shop (August 14, 2021)
Donated
