Go Back   VAF Forums > Model Specific > RV-9/9A
  #971
Old 10-16-2020, 07:43 PM
dwranda dwranda is offline
Default wheel pants done and primed
Finally got the wheel pants and fairings done and primed. They're not perfect but look great from 10 feet away
ID:	3479  Click image for larger version
ID:	3480  Click image for larger version
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid April 2021
Old 10-16-2020, 09:53 PM
airguy's Avatar
airguy airguy is offline
Those look really good! I ran out of patience about 5 minutes before I started on my wheel pants. They fall under the category of "It ain't right, but it's right now."
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 07-27-2021, 06:10 AM
Avoca1us Avoca1us is offline
Default Firewall Forward complete
Thunderbolt IO 360 M1B with piston squirts. Firewall mounted RV 10 oil cooler.
Name:	Firewall Forward.jpg
Old 07-28-2021, 01:46 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Mike, if the paint on those baffles is a preview of the paint on the rest of the aircraft, I think you are going to have one beautiful RV! Very nice!
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 08-13-2021, 09:02 AM
hamblin10's Avatar
hamblin10 hamblin10 is offline
I have to ask why I see so many RV-9/9A builds installing 360 engines when the recommended maximum is a 320? You still should not exceed Vne, and it adds weight and fuel burn. The only advantage I can see would be on climb performance if you live up in Leadville. Am I missing something. Would like to know as I plan out a -9A. Thanks!
Eric Hamblin
Private Pilot/A&P/Aerospace Engineer
RV-12iS in progress. N993EZ
Build 121398
Empennage kit ordered 9/30/21
Wing kit ordered 11/8/21
Owasso Oklahoma
https://eaabuilderslog.org/?s=MYRV12
Old 08-13-2021, 09:16 AM
Jesse's Avatar
Jesse Jesse is offline
My understanding is that the cost of the 360 vs the 320 is not very significant, and the weight is not very significant. The cruise speed would be better with 180HP and climb performance would certainly be better. I'm not condoning or condemning.
Jesse Saint
Old 08-13-2021, 09:39 AM
PilotjohnS PilotjohnS is offline
Default My thoughts
I really thought hard about the 360; it is soooo tempting. but I put in the 320 because I wanted others to be safe. the 360 can fly real close to Vne and any push over during cruise risks exceeding Vne. For the conscientious pilot it is not a problem. But if my son or daughters were to fly my plane, or someone not as familiar, I am worried it would be a problem. Others have the need for the extra power, but i don't, so i didn't. The fuse is the same firewall forward as the RV7, so a 360 is not that hard to shoe horn in.
John S
Dues paid 2021, worth every penny
RV9A- Status:
95% done, 5% left to go
Electrical/Panel done
Firewall Forward 95% done (waiting on fiberglass to be done)
Fiberglass 5%
Old 08-13-2021, 06:23 PM
airguy's Avatar
The throttle is simply one of many controls that the pilot must handle correctly to keep the airplane within its flight envelope. You can exceed Vne without the engine running at all with just the elevator.
Be a pilot, not a passenger.
Old 09-30-2021, 09:29 PM
Default Almost a 14 mod done and rear window installed
I just finished the install of the Almost a 14 mod. I had it done once, but I chose to install the aftermarket flap motor and that doesn't jive with the lower bar that's needed with the mod. I ended up installing the push pull cable. I had to make custom brackets to hold the cable on each side. I think it came out pretty good for an amateur. I also just got the rear window installed with sikaflex. It's not cosmetically perfect(look at Bruce Hill's and Bruce Swayze's sites and you'll see what my goal was) but is good enough. Thanks to the 2 Bruces for their great build sites!!
9A in progress
