  #11
Old 03-18-2022, 06:22 AM
Ingo Weise Ingo Weise is offline
Default Enjoy it!
Why not? I fly navigation rallies with my Mooney at 90 knots. It’s fun, and the slower you fly the more time you have to find the targets on the ground, or in your case to enjoy the landscape.
Ingo Weise
Celle, Germany
RV-8 slowest build, D-EXKI reserved
Tail finished
Wings ordered
Old 03-18-2022, 06:42 AM
pa38112 pa38112 is offline
You RV can fly slow no problem, but your Lycoming is another issue. Assuming you will be burining 100LL, flying that slow for extended periods you will be accumulating lead build-up in the engine. You will also find that you get horrable fuel efficency.
When I fly long distances with my kids (flying a Tomahawk) I let them leave before me, and plan on passing them at the 1/2 way point. This way we are able to stay in almost constant raido contact.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
2008 Wag-Aero Cub C-85
Old 03-18-2022, 06:56 AM
turbo's Avatar
turbo turbo is offline
Talking
great post. I suggest you give it a try and report back with your experience. definitely doable.
TURBO YES =VAF= Payed Jan2022
Ed D'Arcy
RV6-A 5,400+ hrs, R-44 1,700 hrs, Helicycle traded for 33 FFR coupe, 300 young eagles flown
Stuart, Fl / East Hampton,Ct / Virgin Gorda, BVI - villa sold.
addicted pickle ball player
Old 03-18-2022, 08:03 AM
claycookiemonster's Avatar
claycookiemonster claycookiemonster is offline
Awesome insights, all. Sleeping late and leaving behind him, and then waiting for him on the ramp with coffee at the end sounds perfect.
Clay "Cookiemonster" Cook
USAF: T-38, F-111F
American Airlines: 727, MD80, 757, 767, 737
RV8 #81751 project sold
RV8 #81651 project acquired
https://theonceandfutureflyer.wordpress.com/
Donations up to date thru December 2015
"...serenity...courage...and wisdom..."
Old 03-18-2022, 08:13 AM
fl-mike's Avatar
fl-mike fl-mike is offline
The Carson's speed for the 8 is around 140 mph, 122 knots.
https://vansairforce.net/community/s...d.php?t=134077
Mike W
Venice, FL
N164WM RV-6A Slider/O-360/FP Sold 4/2022
N184WM (RV-8) Final stages. Titan IOX-370
N184P reserved (RV-8QB) Empennage
Old 03-18-2022, 08:39 AM
iwannarv iwannarv is offline
Find what your best MPG speed/power setting is, and fly that. You'll still be faster than him at that power setting, but if you let him depart first and land last, you will have a little time to help with logistics on both ends as a favor.
Really, doing that along with finding each other/joining up for a bit in the middle of each leg just for fun - I bet you won't find yourself waiting for him all that long at each stop. You'll stay entertained and fly efficiently. Plus the trip will be a great example of enjoying the getting there over just getting there.
Brad Brensing
RV-10 Emp/Tailcone - Complete, QB Wings - Complete, Fuse - Complete, Finish Kit - In Progress.... (Doors )
Never judge a man by his trim tabs.
Old 03-18-2022, 09:09 AM
Walt's Avatar
Walt Walt is offline
Originally Posted by RV6_flyer View Post
I frequently fly by myself at 2,100 RPM and 22 inches. That give me right at 122 KIAS and 6 GPH or less fuel burn. In my airplane, that is a very comfortable power setting.
Hopefully you're not flying in a prop 'restricted' range, most Lyc publications list 2350 as the lower limit on RPM for cruise with a 360 for what it's worth.
Most of the Hartzell prop restrictions are for 2100-2350, likely because there are more harmonics down that low.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 03-18-2022, 10:58 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Hi Walt, I've got the io-360 from Mattituck, pmags, FM-200, and the Hartzell 2-blade C2YR-1BFP/F74972 metal prop. I can't find any RPM restrictions, but it does feel like there are some vibrations when I go below about 2200. I thought it might just be prop balancing, which I plan to do soon. Mine feels smooth above 2200, and when I'm in "slow cruise" I'm usually at 2250. While I can't seem to find a specific RPM restriction, I am curious if there are some recommendations to avoid particular RPMs due to harmonics. It seems that this combination must be pretty-well researched, so I doubt I'm breaking much new ground with this question. Thanks for any insights.
Mickey Coggins
http://www.rv8.ch/help-people-in-ukraine/
Old 03-18-2022, 11:49 AM
Walt's Avatar
No limitations on that prop with standard mags and compression (assuming 180hp 360), not aware if Hartzell has done any testing with dual Pmags though.
Old 03-18-2022, 01:59 PM
SuperCubDriver SuperCubDriver is offline
At 45% power with 2000 RPM I burn 6 GPH and indicate like 123 kts with reduced noise levels. At this lower RPM the oil temperature is actually lower despite the lower speed. My engine(s) donīt like power settings below 40%.
RV-7 flying, IO-375 w. P-Mags, 200RV Prop
RV-8 flying, IO-375, P-Mags, 74RV Prop
