Old 01-30-2016, 03:50 AM
KRviator's Avatar
KRviator KRviator is offline
Default Carson's speed for RV's.
I got bored today and got to thinking what is the best speed to fly in my -9 for the least amount of fuel used, which is commonly known as Carson's speed. Fortunately, I fly (or at least, will very soon fly) an RV-9A, for which CAFE performance data is readily available, via their APR flight testing.
The EAA reports Carson's speed is 1.316x the best glide (best L/D) speed, which CAFE measured as 95 MPH for the RV-9A.
Then I got thinking that maybe other RVators could benefit from having their efficiency data in one place, so I did a little digging and came up with the following numbers. Glide speed has been sourced from, in order of preference: Factory data (in the case of the RV12 for example) CAFE APR's where available, finally, averaged from Builder's POH's reports of their phase 1 test results, with the references provided alongside.
So, for the various RV models, we have the theoretical best MPG speeds as follows, normalized to SMPH:
RV-1:
RV-3: 110.5 SMPH - (Avg of 73 KIAS - N223RL POH, only one so far!)
RV-4: 111.1 SMPH - (Avg of 71 KIAS N359DM POH, 82 MPH - C-GFEW POH, 80KIAS - N41RV POH)
RV-6: 139.5 SMPH - CAFE RV-6 APR
RV-7: 120.1 SMPH - (Avg of 90MPH - N2447A POH, 78KIAS - N447RV POH, 85KIAS - HB-YMT AFM, 78KIAS N585RV POH)
RV-8: 140.5 SMPH - CAFE RV-8A APR
RV-9: 125.0 SMPH - CAFE RV-9A APR
RV-10: 131.2 SMPH - (Avg of 80KIAS- N423CF POH, 90KIAS - N961M POH, 90KIAS - N42BU POH)
RV-11: - I'll ask Van when he finishes it. But how do you measure "fuel"?!?
RV-12: 95.4 SMPH - Vans Factory POH. Can't beat that!
RV-13: Classified - Believed to be in excess of 760 SMPH. If I ever feel the need to break into Area 51, I'll update this one!
RV-14: To be added "soon".
Now, these are not meant to be definitive, and may well vary with individual aircraft - look at the variation in best glide speed and reported glide ratio's for the "same" aircraft, but should be enough to get you in the ballpark for your own testing, if you're that way inclined.
Also, bear in mind best glide speed varies with weight though ratio will remain constant, so variation in test conditions among the various owner's will distort the data somewhat, hence using average values.
Finally, don't blame me if you run out of fuel using these numbers to attempt a Hawaii-LAX flight, it's worth what you paid for it!
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 01-30-2016, 06:21 AM
Interesting information Rob.
I don't plan to fly to Hawaii in an RV but do wonder why the 20 mph spread between RV-7 and RV-8, the aircraft have the same wing just different fuselage.
I suspect if one got serious about establishing the Carson number for the 8 it would be less than 140 mph.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 01-30-2016, 06:49 AM
Kevin Horton's Avatar
One small clarification - Carson's speed is not the speed for best miles per gallon. The speed for maximum miles per gallon is the best glide speed (ignoring any effect of head or tail winds). No one wants to fly that slowly, unless you absolutely must squeeze every possible mile out of the fuel you have on board.
Update - Ignore the following sentence in my original post, which was complete hogwash: "Carson's speed is the speed that gives the highest ratio of speed to fuel flow". Most people in RVs don't want to fly that slowly either.
Kevin Horton
RV-8 (Sold)
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 01-30-2016, 07:05 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Carson's speed is the speed that gives the highest ratio of speed to fuel flow. Most people in RVs don't want to fly that slowly either.
I must be missing something at this early hour. Seems to me that the ratio of speed to fuel flow is:
(miles / hour) divided by (gallons / hour) = miles / gallon
For more than you ever really wanted to know, here's a fun read: http://www.flyingmag.com/very-best-speed-fly
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
Vaccines kept me out of the hospital but COVID still cost me a month of living, all told...
Old 01-30-2016, 08:18 AM
AlexPeterson's Avatar
Wouldn't best glide speed be lowest fuel burn rate to stay in level flight? Different from best mpg.
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
Old 01-30-2016, 09:39 AM
brad walton brad walton is offline
Best glide, best L/D, would result in best miles per gallon. Not the same as Carson speed which is 1.316 x best L/D. My best L/D is about 100 ktas, so my Carson speed is about 131 ktas
Old 01-30-2016, 10:58 AM
Jordan1976 Jordan1976 is offline
The issue with Carson's speed is that it ignores the efficiency curve of the propulsion system. It assumes that you can create 1 HP as efficiently as 100 HP, and that your prop takes HP and turns it into thrust with the same efficiency at 1000 RPM as it does at 2700 RPM or at 50 Knots or 150 Knots.
Best range comes from best MPG, but MPG is an intersection of lowest drag and the efficiency of your propulsion system to creating thrust from fuel.
Most engines that burn fuel get more efficient at higher power outputs. Thus, while aerodynamically you may have the best efficiency at the Carson speed, if you have your engine at 40% power to do so, you may not have the best MPG possible. You have to add in the effect of the propeller on the plane as well, which will have its own efficiency curve.
Starting a test at the Carsons speed makes sense because it is highly unlikely you need to go slower than that, but it is not surprising if actual peak MPG is achieved at speeds higher than the Carsons speed.
Old 01-30-2016, 12:06 PM
David Paule David Paule is online now
On a practical basis, flying that slow means that you're more susceptible to winds aloft. In fact, Carson's speed, like the L/D speed, must depend on the winds aloft. If you have a headwind, it'll be faster and in a tailwind it'll be slower.
Dave
Old 01-30-2016, 01:05 PM
Why? It seems some are confusing lowest fuel burn rate with best mpg, which isn't the case.
Not considering prop and engine efficiencies (at various settings), the lowest gal/hr would be at lowest overall drag, or best glide (about). However, for example, if one added 10% more fuel burn, but got 20% more speed, it would result in a higher mpg. I'm not saying these are the numbers, but are for demonstration only.
Alex Peterson
KADC, Wadena, MN
Last edited by AlexPeterson : 01-30-2016 at 07:59 PM. Reason: removed redundant link
Old 01-30-2016, 02:18 PM
g zero g zero is offline
Default Carson
Fuel cost are only part of the total cost to go from point to point . Sure you might burn less fuel by going slower but more time on the oil , prop and engine ,etc. Add them up and it's over $20 hour easily before you pay for fuel.
My 8 gets great mileage above 8000' @ 175 knots cruise ( 25 mpg / no wind) seems like the "sweet spot".
Rv8
N 666 TA
First Flight 2-3-2015 🚀
