  #21
Old 10-10-2021, 04:32 PM
wilddog wilddog is offline
The start arm switch is hidden. The "starter armed" warning light (a flashing LED) ensures I don't forget to turn it off. The relay means no significant current at tiny grip switch.
Right hand, stick back and start command. Left hand, throttle, mixture, purge valve.
About 1000 hours now.
That is the same way I wired mine. Also have the PTT button on the throttle. RV-8.
Old 10-10-2021, 06:26 PM
jakej jakej is offline
I see 1 excellent exception to comments so far re starter switch on the stick - ie when using the VPX bus system. Am really surprised no one has mentioned this before as there are a lot of VPX systems installed now. Personally the only reason I see the need for a starter on the stick is with tail draggers - absolutely no need to with nose wheel aircraft.
VPX - when the revs are above 500 rpm the starter circuit is disabled therefore accidentally touching the starter button will not activate the starter
Old 10-11-2021, 10:07 AM
rapid_ascent rapid_ascent is online now
I'm curious how much current is required for the starter solenoid. I'm still not committed to having the switch yet either. I do think if you need a panel disable switch and another relay that maybe its not worth having a stick switch.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 10-11-2021, 10:15 AM
Norman CYYJ Norman CYYJ is offline
Yes you will need a relay. Make sure you put a clamping diode across it or you will run the risk of burning out the switch on your stick.
Old 10-11-2021, 12:54 PM
dpansier's Avatar
dpansier dpansier is offline
Default Contactor current draw
The starter contactor draws 3.5 Amps and the Battery contactor 720 milliamps, both measured on my aircraft.
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 10-11-2021, 01:09 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
I suspect this 3.5amps in holding current. Surge latch current might be a lot higher.
The standard switch (not top hat) on an Infinity Grip is rated at 6 amps. I would not use that as a a basis to skip using the grip switch to operate a simple, 100ma relay that would then power the starter solenoid.
Pitted switch contacts need be avoided.
Carl
Old 10-11-2021, 01:37 PM
dpansier's Avatar
Yes I agree this is the holding current, I could haul out the O Scope with the current probe and get the peak but it is not worth the hassle. <G>
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Old 10-11-2021, 09:27 PM
skylor's Avatar
skylor skylor is offline
Default No stick starter switch on the stick here…
I think this is much ado about nothing.
On my -8, it’s really easy to hold the stick back between my legs during engine start. To me, this is much easier and simpler than adding a bunch of extra wires, relays and disable switches to add a starter button to the stick!
Keep it simple!
Skylor
p.s. You’ll thank me if you ever have to troubleshoot an intermittent starter issue…
Old 10-12-2021, 06:29 AM
Harald's Avatar
Harald Harald is offline
Default Infinity Stick Grip with engine start button
I have Infinity stick grips with switches for the functions engine start, trim, flaps, AP con/disc, fuel pump and PTT. They works perfect! For safety reasons the engine start button needs to be cleared or activated pressing a separate button switch for 2 or more seconds. This switch is located near the trottle knob and has an integrated led that flashes while the the engine start button on the grip is „hot". The engine start button will remain active until it was released or the clearance/activation switch was pressed for two seconds or more. I implemented this solution using a small programmable relay Eaton easy 500. The flap switch on the grip just uses the G3X airspeed limit protection function and in my configuration it is only activated below 87kts.
Harald Sotomayor
D-ESOT flying
RV-7 #72535
Titan IO-360, MT-Prop
Old 10-12-2021, 07:05 AM
wcalvert's Avatar
wcalvert wcalvert is offline
Clearly two different camps here. Whatever level of Gee Whiz you choose to build (low or high, for your own good reasons), just be sure you have a way to avoid blowing the starter or ring gear off your motor by inadvertently touching the wrong button.
And keep in mind that without proficiency (training and perfect practice), all the little details of function become a whole 'nother ball O bees when the stuff hits the fan or you can't see due to smoke or injury.
Just sayin' ... be careful out there.
Cheers
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
First Flight 7/17/2021!!
- Been there, Donated 2021
