  #21
Old 08-25-2021, 07:48 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Try this
Hey Moe,
I don't think you need to remove the gear legs. If all you need is an additional 3/32 inch of clearance I think you can remove the inner three bolts that secure the end of the gear leg and this should allow the leg to pivot slightly to give you room to extract the fittings. The large outer block is designed with a slight radius in it to allow the gear leg to flex around the radius rather than a square corner. There just might be enough play to rotate the gear leg enough to give you that 3/32 inch. Those three bolts are a lot easier to pull than the two that are buried the gear tower.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours- Sold
My Aerobatic Video
My Formation Video
CAF B-25 - Airbase Arizona
VAF 2021 Donor
Old 08-28-2021, 02:31 PM
rv8gibbo rv8gibbo is offline
I'd bite the bullet and remove it for what it's worth..
An engine crane and sling around the engine mount and away
you go.
Old 08-29-2021, 09:42 AM
Toobuilder's Avatar
Im using 1/8 OD (yes, same as fuel injector lines) for brakes on the Rocket. This uses the cone compression fittings to seal and so far has been flawless. Ill bet a 90 degree compression fitting will thread into that leg once the much longer AN fitting is removed. You would have to run new hardline up to the flex hose above the rudder pedals, but the 1/8 hardline is a breeze to work with.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 08-30-2021, 02:04 AM
dmn056 dmn056 is offline
Default NPT banjo bolt?
Tom, you're an expert on this stuff. Have you ever seen or used anything like this?
Click image for larger version
https://www.ebay.co.uk/itm/171414187...YAAOSwDk5T428f
Would it be useful here?
Dan Newman
RV-8
empennage complete
wings complete
fuselage in progress
Old 08-31-2021, 12:19 PM
moespeeds moespeeds is offline
I think that'd be really useful.
I ended up cutting out the old fittings, and replacing them with 1200 PSI brass street elbows and AN4 straights. I also ditched the aluminum hard line for super flexible aramid PTFE.
Saved me from pulling the gear legs, and now it's actually serviceable. I have new bolts and the heavy duty nuts on order, and I got a set of the bolt locks so I don't have to torque in the gear tower.
Thanks guys.
Attachment 15239
Moe Colontonio
Cherry Hill, NJ
RV-8 N495T
Old 08-31-2021, 01:21 PM
jrs14855 jrs14855 is offline
Default Brake Line
Moe-
Nice to see my idea worked after 12 days of "gotta remove the gear." For the "next guy" the 90 degree fittings are also available in AN but I believe they require just slightly more clearance than the automotive/industrial.
Old 08-31-2021, 02:53 PM
The banjos are a good idea---on paper.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 09-01-2021, 10:09 AM
g zero g zero is offline
Default Leaking Elbow
I’ve be involved with plumbing for my entire life . Pipe dope works almost all the time ………. Recently we had some gas and water fittings that leaked no matter how tight we made them up with pipe dope . We now put them together with West Epoxy instead of pipe dope . Works perfectly.
Rv8
N 666 TA
First Flight 2-3-2015 🚀
Old 09-01-2021, 10:53 PM
I'll add this---
I didnt see this as a -4 with either 1/8 or 1/4 NPT. The bolt has a female Torx hex head, and you'd need a really short Torx bit with a wrench in the space allowed. Would be better if there was a hex on the stud under the banjo. The other thing is the brakes are under alot higher pressure that your fuel system, and with that, any movement in the banjo 'may' allow some small volume of air to migrate into the system. The more air in the system, the softer the pedal.
Still easier to just reseal the AN fitting and go fly.
Tom
Ridgeland, SC
Old 09-26-2021, 09:05 PM
goatflieg's Avatar
goatflieg goatflieg is offline
Originally Posted by jrs14855 View Post
Moe-
Turns out I'm the next guy. Any and all details you or Moe can give me would be extremely helpful. There's no way I'm pulling a gear leg at this late stage. Something else occurs to me: I wouldn't connect any aluminum to a brass fitting because of galvanic corrosion. Your thoughts?
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - registered; final assembly continues; still putting out my own brush fires.
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2021... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
