VAF on Twitter:
@VansAirForceNet
  #21
Old 01-11-2023, 06:21 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Mich48041 in above two posts, is giving good advice... The John Deere AM101406 ($20 on Amazon) works very well with Rotax 912ULS and Odyssey PC680 Battery. I have mine mounted in original position on firewall shelf with no additional ventilation. It is mounted on a sub-plate using thermal heat paste. I'm guessing close to 400 hours since install. I carry a spare in the baggage compartment that's never been used....
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 830
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 01-17-2023, 06:35 PM
Schumway Schumway is offline
Last week the Amazon voltage regulator arrived and I did not install. It was half the size of the Ducati VR and quality was questionable so I went with the B&C XB100-2. That arrived today and looks exceptionally nice. Was shipped in a presentation quality box as a bonus! Install is almost done, but I forgot to bring my wife's hairdryer for the heat shrink tubing. I will finish up tomorrow, but I am a bit nervous. Changed engine oil and I did not clean the oil tank. I was concerned about removing hoses from the top of tank and then having to purge air from the lines. Lack of experience so I am taking small steps.
Click image for larger version
Respectfully,
Frederick Miller
RV-12
N563ST
Old 01-18-2023, 07:06 PM
Buttoned up voltage regulator install today and pulled RV out for a run-up. All good! 14.1 volts. B&C bolted in place of original Ducati on the firewall shelf. New connector body fitted as well.
Respectfully,
Frederick Miller
RV-12
N563ST
Old 01-18-2023, 09:11 PM
R100RS R100RS is offline
Originally Posted by Schumway View Post
...so I went with the B&C XB100-2.
Isn't the regulator in the photo a B&C AVC1, made specifically for the 912 ULS series engine? That's what the box indicates, and that is what I have in my two 912 ULS-powered aircraft.
Old 01-18-2023, 10:45 PM
RV8JD's Avatar
RV8JD RV8JD is offline
They are the same item. "AVC1 Advanced Voltage Controller" is the name. "XB100-2" is the P/N.
https://bandc.com/product/avc1-advan...stallation-kit
"PART #: XB100-2
AVC1 Advanced Voltage Controller (14V)"
Carl N.
RV-8
KAWO
Old 01-19-2023, 11:21 PM
RFSchaller RFSchaller is offline
I didn’t open my oil tank to clean and inspect until 1200 hours and 11 years. It was clean as a whistle. I waited to avoid the purge process PITA.
