Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
08-30-2022, 05:16 PM
Originally Posted by rv6ejguy
Wouldn't a run up have discovered this on the ground?
Probably only a high power run up….most run ups are what say 1700 rpm….then 1000 and a dead cut check….so I’d think no….it was starvation at high power caused by the fitted restriction….
2022 dues paid gratefully. great site for help and info.
08-30-2022, 05:17 PM
Very unfortunate, probably some young A&P who has never worked on an RV and there was no way for him to know that was a special fitting.
Perhaps fittings like that should be identified somehow as ‘non-standard’, maybe painted red?
I’ve seen lots of ‘WTF’ stuff where someone had no clue, so it pays to have your RV work done by a ‘specialist’ who is familiar with the systems we have that are not seen on most GA aircraft. I suspect many RV guys would have caught that mistake.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
08-30-2022, 06:31 PM
I don't think you can make 75ish hp with that size orifice...
08-30-2022, 06:50 PM
^^^^The winner! Who does work on a fuel line and doesn’t follow it up with some careful ground testing?
08-30-2022, 06:59 PM
That's really a sad situation. Its a very basic fuel setup to mess it up so badly. It's a shame to lose a plane and have serious injuries for something like this.
Ray Tonks
2022 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
Sensenich Composite 3 Blade Propeller
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
08-30-2022, 07:01 PM
would'a - should'a - could'a
After modifying fuel system (adding fuel flow) it would be wise to do a fuel flow test?
sender could be jammed, line could be collapsed, or in this case the totally unexpected wrong fitting.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
08-30-2022, 07:04 PM
Digging in to the NTSB docket, there are 5 items to VIEW at the lower right. The third is the Maintenance Record 5/24/21. Shows who did the work. Also indicates “Aircraft was Groundrun by the owner to confirm all systems operational”.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
1,000+ Hours & 7X cross the USA
OSH flyin 2018, 2019 & 2022.
Petit Jean 2019, 2021 & 2022
08-30-2022, 07:45 PM
A short ground run may not have shown it. Someone else should check but I calculated an 0360 at 1800 rpm might only use 3 ounces in a 10 second ground run. The restrictor may have filled the float bowl while it was idling.
Mike
N36MB
SN 83764
IO360-M1B
Hartzell Composite CS
Phase 1 complete 10/29/22
KAJO
08-30-2022, 07:58 PM
Yes, I think that is a likely assumption. It would take a loooooong ground run to empty the float bowl.
Best to disconnect the hose at the carburetor and put it in a bucket. Run the boost pump for 30 seconds or so and measure the volume in the bucket. For a properly functioning system, you should get something like 30 gal/hr or more.
Had they done this, they would have gotten a trickle, and would have known something was wrong.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 725
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2022
08-30-2022, 09:54 PM
Absolutely, I have recommended it several times here , remove at the carb in this case back pressure the outlet and run at 125% of max engine fuel flow with the boost pump.
But, normal mechanics are not wired that way. They always (well 99%) assume that the design is correct and only a part is broken. A prototype mechanic was trained/wired to check everything - like a good builder.
Bill
RV-7
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
