VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Main > Safety
  #131
Old 08-23-2022, 09:56 PM
scsmith scsmith is offline
Originally Posted by Snowflake View Post
While the vertical stabs have failed in these accidents, it's happened after other items failed first (ie. the rudder). The forward spar on the vertical stab is a red herring. Reinforcing the attach point of the vertical stab as AntiSplat suggests just creates stress concentrations elsewhere.
I agree with this. In at least one of the two cases, the attach bracket that Anti-splat replaces with a stainless steel one was NOT the final failure point either. The fwd fin spar actually tore right above the attach bracket. I think BillL has a really good photo showing this.
Although this point was not the initial failure (other stuff broke first), the stiffness at this point may contribute to the flutter boundary. In Rockets, and several Reno-racing RVs, the fwd fin spar gets a doubler that runs part way up (to the middle rib IIRC) which stiffens the fin in torsion (and also somewhat in bending). With this added thickness from the standard fin spar plus the doubler, a thicker attach bracket should also be used. The rear fin spar also gets additional strengthening/stiffening.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 725
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2022
Old 08-23-2022, 10:32 PM
sailsunfurled sailsunfurled is offline
Did the pre 2002 -7 come standard with -8 rudder?
RV-7A in progress
2022 Dues Paid
Old 08-23-2022, 10:54 PM
jask jask is offline
Yes, it came with the 8 rudder.
RV-7 builder Ramona, CA.
Free prop balancing for Van’s owners.
RV-6A N665CM
Old 08-23-2022, 11:21 PM
Thanks for verifying what I thought I read sometime ago.
I took over a -7 build this past year (wings and tail partially built). It had the original rudder, 2001 was the year of the tail kit order. While waiting for my fuselage kit, ordered Nov. 2021, I requested the free larger rudder mentioned in Van’s service bulletin to make some movement on my build.
I am in the middle of building the new rudder when I noticed this thread. I will finish the larger rudder for the practice and to hone my skills but install the original “8” rudder.
Informative thread and reading, thanks all for your contributions and view points.
RV-7A in progress
2022 Dues Paid
Old 08-24-2022, 12:05 AM
Good plan.
RV-6A N665CM
Old 08-24-2022, 09:27 AM
mburch's Avatar
mburch mburch is offline
Originally Posted by Thermos View Post
Although the RV-10 and -14 rudders still have riveted trailing edges, the internal structure is different from that in the-7/9. Stiffeners are tied to the rudder spar with shear clips, and the stiffeners themselves are much more robust - the horizontal flanges are joined to their mates on the opposite side with a rivet about halfway down the rudder chord. Also, the counterweight skin is integral to the rudder skin and not riveted on as with the -7/9.
My professional flight test work has only dealt with structures and flutter at a conversational level, but my sense is that these changes make the rudder quite a bit stiffer. Only Van's can say whether those changes were remedies for a weakness in the -7/9 rudder design, or if they were done for another reason.
This is a thread that seems worth pulling on. The numbering of the individual components that comprise the RV-14 rudder are similar enough to the corresponding RV-7 rudder parts that it leads me to think that an RV-14 rudder ought to bolt right on to an RV-7 VS. Assuming that's true, it would be interesting to explore why two in-production aircraft designs use rudders that are the same external size but have different parts and internal structure... especially considering that there haven't been any known in-flight breakups of RV-14s
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
Any opinions expressed in this message are my own and not those of my employer.
Old 08-24-2022, 10:48 AM
wirejock's Avatar
wirejock wirejock is online now
Default Vans
14 pages of comments.
Numerous posts about changing Vans design or components.
Did I miss a Vans comment?
Seems like they would have something to add.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 08-24-2022, 11:04 AM
airguy's Avatar
airguy airguy is offline
If there were something noteworthy to add, yes.
So far this is nothing but conjecture that "something is wrong" - but it's all based on pilots exceeding the published limits of the airplane. Vans will most likely not make any comment at all on accidents where the pilot exceeded the limits of the airplane - the cause of the problem there is obvious. Don't do that.
Is there any evidence at all that shows a failure while WITHIN the published limits of the airplane? Did I miss something?
Garden City, TX VAF 2023 dues paid
N16GN flying 1,250 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Repeat Offender - 10 empennage in process.
Old 08-24-2022, 07:03 PM
PilotjohnS PilotjohnS is offline
Default Before we leave this topic
In my model airplane days, I was always trying to get my control surfaces stiffer for no added mass. I found that offsetting the tail ribs so the were not parallel increase the stiffness immensely with very little weight gain. When I started playing with real airplanes, I was surprised to see all the tail surfaces ribs running parallel based on what I “knew” from models. Perhaps the analysis tools are better now and non-parallel ribs can be assessed for if they provide greater stiffness with only minimal weight increase.
OK I am done with this topic, you may close the thread now. Because it is all about me anyway.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2023, worth every penny
RV9A- Status:
98% done, 2% left to go
To Go: wing mounting, engine baffles, wing tips, move to airport
www.pilotjohnsrv9.blogspot.com
Old 08-24-2022, 08:02 PM
wirejock's Avatar
Default Speculation
Originally Posted by airguy View Post
<snip>
Nope. You said it. I was trying to say that without my usual obnoxiois opinion. Thx
Larry Larson
Estes Park, CO
Disclaimer
