Van's Aircraft announced today that we have reviewed, approved and are now selling Lycoming IO-390A (210HP) engines for RV-7/7A and RV-8/8A aircraft. Support for installation is limited since we do not have a FWF kit specific to this engine. Many community members have used this engine on their 7's and 8's already.
All the details: https://www.vansaircraft.com/2020/05/vans-approves-use-of-io-390a-on-rv-7-and-rv-8-aircraft/
Added: This means RV-7/7A and RV-8/8A builders can now order an IO-390A from Van's and take advantage of the OEM discount opportunity as well as the prop/engine-bundle deal. Engines are available only to RV builders with a Van’s customer number (aircraft serial number) and must be installed on the corresponding airplane. Builders must have purchased, or have already on order, all kits through the Finishing Kit for that aircraft serial number, and one engine per aircraft serial number may be purchased. Sometimes people ask if they purchased an engine from another source and want to get a new engine to install on their existing airplane, can they do that? As long as an engine has not been purchased for that airplane, then yes - the offer is still open, and you do not have to be the original builder/owner to take advantage of the OEM pricing program. As long as your airplane has not had a new engine purchase associated with it, it's eligible. Hope that helps answer some questions!
