Old 09-01-2020, 08:38 AM
ebackscheider ebackscheider is offline
Latintan1, what did you use for an audio panel with two radios? I like your setup!
Eric Backscheider
2020 Dues Paid!
RV6 - N6014Y - Flying
Pitts S2B - 245JH - Sold
CFI - Acro in the 6 Rocks!
StopFlyingScared.com
Old 09-03-2020, 02:41 PM
Brdog42's Avatar
Brdog42 Brdog42 is offline
Default Budget VFR Panel...
I’m re-building a 6A. The original panel was analog with cast-off, but functional equipment. Items from Piper, Cessna, Terra, etc. were used in the spirit of simplicity and low costs. I don’t think anything was purchased new for the original panel. I’ve tried to keep that theme going from the original builder.
A friend was able to scrounge a big piece of .063” 2024 from a dumpster. A friend put a nice 90* bend on it with his brake. After a few hours in & out of the -6, I had the basic blank. I added .75” extra to the lower portion. Still high enough to clear occupants’ knees. The only new item on the panel is the GTR200. It’s just too good of a value on a single COMM / VFR aircraft to pass up. Even the air vents were scrounged from the dumpster. I’m amazed at what people will throw away.
I’m currently working on wiring the panel, at home. 115*F is too hot to be working in the hangar.
This is what I had to start...
ID:	1977  Click image for larger version
ID:	1978  Click image for larger version
Tim
RV-6A restoration in progress
KCHD AZ
Old 09-03-2020, 02:45 PM
Brdog42's Avatar
Default Current progress
This is what Iíve been able to get done...
ID:	1980  Click image for larger version
ID:	1981  Click image for larger version
ID:	1982  Click image for larger version
ID:	1983  Click image for larger version
Tim
KCHD AZ
Old 04-15-2021, 01:13 PM
ColoradoSolar ColoradoSolar is offline
Here is my panel evolution. Original, 1st upgrade from last year and the newly finished panel.
ID:	10416  Click image for larger version
ID:	10417  Click image for larger version
Eric Vickery
RV-6A Tip-Up Bought Flying
Old 05-11-2021, 07:45 AM
Default Day VFR to full Glass conversion
Not 100% done with electronics, but my dash is new and cut and powder coated.
Eric Backscheider
2020 Dues Paid!
