Old 05-14-2020, 09:24 PM
jcarne's Avatar
jcarne jcarne is offline
I also redid the connectors for the ADSB module and transponder as the wires were not all the same length and were not laying nicely. That's about when I took this pic of the newly installed ELT antenna.
20200514_162635 by Jereme Carne, on Flickr
Lots more in the months to come, glad to be back to building!!!
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 05-14-2020, 10:19 PM
kentlik's Avatar
kentlik kentlik is offline
Holy ****! You're done! What the heck, I think this is unfair for some reason LOL!
Good that you will be done so you can travel to Portland and help me wire up my plane as you are obviously just showing off all your skills!
Machine!
PS I did not type four * haha
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 05-17-2020, 01:06 AM
jcarne's Avatar
Machine!
Haha thanks man. Just trying to keep you motivated!
Jereme Carne
PPL
Old 05-17-2020, 11:22 PM
jcarne's Avatar
The work continues! Let me tell you what, this front tunnel cover was no fun! Okay... it was fun, just not the fun I wanted to be working on. As you can see I had to notch it pretty good to get it to slide over the fuel line. On the front left where the 90 degree bend is I was getting too much interference with the brake lines/ wire runs. So I decided the best course of action was to notch it a bit and put a cover plate on there. It turned out great. I was even able to use the piece I cut for the fuel line clearance so no painting needed to be done! Not visible but I also had to notch the upper right for the heater vent cable.
20200517_170320 by Jereme Carne, on Flickr
After much debating and no real good options, this is where I decided to put the cabin heat control. (still needs labeled) Hooking this bad boy up to the vent was a real pain as I was only a one man crew when I really needed a second outside in front of the firewall pushing the bolts in. In the end I'm quite happy with it.
I put it way on the right of the panel for a couple of reasons:
A) I had no room on the left
B) I doubt I will use it too crazy often
C-Z) Let's be real, the wife will be the one in control of that one
20200517_171725 by Jereme Carne, on Flickr
I also figured out where the Alt. air control is going to reside. After searching the forums I really liked this idea that someone posted. It is still very accessible/visible to the pilot but also out of the way and taking up no panel space. I fabricated the bracket and put it on with two LP4-3 rivets, plenty strong for a rarely if ever used cable that requires very little force.
20200517_171717 by Jereme Carne, on Flickr
Jereme Carne
PPL
Old 05-18-2020, 08:30 AM
BillL BillL is offline
Jereme, you might want to think about your location of that ELT alarm as it has a battery to be replaced and that looks like a hard spot to reach!
Bill
RV-7
Old 05-18-2020, 09:43 AM
jcarne's Avatar
Yep I thought that too and was planning a different location but Van's just came out with some slick access covers that go right above that in the forward top skin. Sweet access now!
Jereme Carne
PPL
Old 05-18-2020, 12:00 PM
Ralph Inkster Ralph Inkster is offline
Like wise for the Dynon B/U battery.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 05-19-2020, 12:15 AM
jcarne's Avatar
You bet ya Ralph.
Jereme Carne
PPL
Old 05-19-2020, 12:24 AM
jcarne's Avatar
Onward we go!
First up, manifold pressure sensor, decided to put it right there for easy access and close proximity to the number 3 cylinder.
20200518_112941 by Jereme Carne, on Flickr
Well looky there, I finally managed to get the firewall seams taped.
20200518_112950 by Jereme Carne, on Flickr
The new brake lines from Aircraft Specialty arrived so on they went. These lines are very nice!
20200518_150353 by Jereme Carne, on Flickr
Also on the after work agenda was to create a homebrew brake fluid filling device. I'm happy with it, cost around 30 bucks is all. Now I just got to wait for Van's to send me some Royco 782.
20200518_160232 by Jereme Carne, on Flickr
Sure am getting close to hanging the engine!
Jereme Carne
PPL
Old 05-20-2020, 11:15 AM
kentlik's Avatar
Well...we talked on the phone about this exorbitant pace you are on so no need to rehash how unfair it is that you work so fast...
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
