If u have a zip tie gun it tighens and breaks the excess off and u do not get cut. I use them everywhere, close to engine under dash etc, 2 yrs now not a problem
Zip Tie Gun? Never heard of that. Where do I get one? Home Depot?
Tie Gun. Bah! Practice putting zip ties on with one hand, blindfolded. You will have to do it someday.![]()
The FAA FADO inspector made me remove ALL zip ties FWF and replace with Adel clamps. -- this was after my A&P spent a lot of time making fancy standoff ties up front.
One more example of an FAA inspector makign up his own rules.
Advisory Circular 43.13-1B
AC's are not regulatory.
Could you show me where exactly 43-13 excludes the use of plastic ties?
I bought a bag of 1000 of these and use them everywhere. I just bought a second bag a week ago. The Ty-Wraps don't have "teeth" along one side of the strap, they're smooth all around... The stainless tang locks in wherever you stop pulling. This leaves a smooth surface against anything you're tied to.I looked up the standards for zip ties for aviation use. They recommend a stainless steel locking tang, and UV tolerant material. I got some of the original Ty-Raps, now owned by Thomas and Betts (T&B).
One is, they cut your hands up when you reach back into your work. Try to cut the excess off as close to the lock as you can.
Two, they will eventually get brittle a break if you use them in a hot area. Other then that they work great.
They make zip tie cutters. Basically, it's a cutting pliers without the bevel so it doesn't leave the little piece that can tear skin.
You can also make one with a belt sander, removing the bevel.
Best,
A new single edge razor blade swiped flush across the top of the "block" of the cable ties will shave them perfectly flush. You can do several dozen before the blade gets dull - very inexpensive.
That's exactly what happens if you don't install them properly. Flush cutters, or a proper tool for setting them and cutting in one motion, and this isn't an issue.This is why A&Ps that work on EXPERIMENTAL aircraft do NOT like extensive use of Zip Ties.
If one scratches me, I stop, cut it off, finish the job at hand, and reinstall properly. One quick swipe with a razor blade or sharp utility knife to score the tie, then pop off the excess. RAYMO, suggest holding the dull side of the knife to cut the tie wrap.![]()
Adel clamps have a way of letting you know they are in your way also.
If you plan your plumbing and wiring to follow existing obstacles like the motor mount, and keep in mind that the filter and mags will need to be removed at some time, it will make future maintenance much more pleasant.
The T&B ty-raps are about $0.07/ea for 1,000 at Newark Electronics
These are cool - they solve my biggest concern with traditional zip ties and that is the edge of the tie cutting through the insulation / shielding material of item being tied. I just ordered 1000 of them and need, maybe, 100. I guess I'll keep half though. So, does anybody want 500 of these for $30 - shipping included?
Too bad I didn't see the response earlier. I'd be interested in getting some of these ties, but not 1000. Maybe 100 or less, preferably in assorted sizes. If anyone is interested in a group buy, maybe we can buy a 1,000 piece package and split them up.
