Rick6a
Jack-of-all-Trades
Fitted with a router bit, the tool can be particularly useful to "pull a hole" to one side if a slight misalignment occurs. I've also successfully done this (fitted with a small stone) on the Plexiglas canopy to enhance screw clearance.
Shown below are the elevator horn clearance cutouts on my RV-8A project, fashioned entirely with a cutoff wheel and followed with a rotary file fitted to a pencil grinder.
Some time ago, I introduced pencil grinder utility to a resident A&P who couldn't figure out how to reach deep inside the air scoop opening of his Cessna to partially file away a rivet head interfering with the smooth operation of the flapper door. After making short work of that little problem, he promptly bought his own copy.
These are just a few of the jobs that come immediately to my mind and personal experience, but am reasonably certain many other tasks await the creative application of this remarkable and utilitarian tool. You already know how helpful it is in RC, I'm sure you can find many other ways to put the Dremel to useful and productive work on your RV project.
Rick Galati RV-6A "Darla" 115 hours
Mike, I use pneumatic pencil grinders (used the same way as a Dremel) frequently in aircraft construction. Fitted with a ball file or ball stone, this tool is very handy to quickly debur holes. Fitted with a cut off wheel, it can be used to rough in an opening or remove excessive threads protruding from a screw or bolt. It is the ideal tool for polishing out small scratches or nicks in metal, especially useful if you have a nick or a gouge on the inside radius of an angle that really should be blended out. Fitted with a high speed rotary file, it can finesse a tight radius almost anywhere. I use it to apply the finishing touches to all manner of openings.mlwynn said:..............I have a dremel tool, have used in extensively in RC but haven't found a use in RV assembly. How are you guys using them?
Michael Wynn RV 8 Wings (tanks)
![img00082016uu.jpg](/proxy.php?image=http%3A%2F%2Fimg93.imageshack.us%2Fimg93%2F6595%2Fimg00082016uu.jpg&hash=36a8405fda33e55f3c97e169ddd40933)
![pencilgrinder2146ah.jpg](/proxy.php?image=http%3A%2F%2Fimg135.imageshack.us%2Fimg135%2F4133%2Fpencilgrinder2146ah.jpg&hash=c92b75f19675678d3637a105825a4fe7)
