You Are Installing SkyView
RV12Roger
Active Member
I do not have SkyView yet but I did receive my Autopilot Kit a couple months ago and would like to install it now.
Should I make all the wiring connections now -or- should I wait? Is there a lot of re-wire relative to the Autopilot that I will have to do with the new wire harness for SkyView?
In any case, physically installing the servos and hardware would be OK now - right?
You need to call Vans. It probably depends on if you installed the "old" fuselage wiring harness or the new one, which would have depended on when you got your finish kit. If you installed the old harness, wire it up! Your adapter harnesses will take care of that. The physical installation - YES - very easy with the fuselage tub on its side and the tail not yet attached.
