Below are a couple of pictures of an RV14 HS-1004 Inspar Rib. Notice that the the rivet in the middle doesn't look like the ones on either side of it. I managed to drop the bucking bar and hit the rivet causing the skin around it to be deformed... kinda like a crappy looking dimple The rib is .025 and so is the flange behind it.
I've considered: 1. Leaving it; 2. Remove it and flatten. This would allow me to check for any cracks around the hole. 3. Flatten it while the rivet is in place.
Before, I check with Van's, figured I'd check here first in case others have managed to do this too. Thanks for any help.
The pictures do make it look worse than it is.
[/URL][/IMG]
[/URL][/IMG]
