Minor technical note for future searchers...
I assume the OP has a standard Lycoming filter adapter which places the filter horizontal, pointing aft, and the issue with the -6 is clearance to the firewall. The Lycoming adapter has a built-in bypass valve. The 51068 has its own bypass inside the filter (as does the 51515), which opens at a lower pressure than the adapter bypass. It's not a terrible thing, but it does mean bypass flow will begin at a lower threshold.
The 51515 and 51068 are perfect for any of the angled adapters which do not have a bypass built in to the adapter.
For a Lycoming adapter on an RV-8, I'd suggest a 51647, which has no bypass in the filter. Might be too long for the -6.
Wix bypass module:
Same module shape fills the space in no-bypass filters
