Aussieflyer
Active Member
I was just fitting everything off for painting (making sure I had not missed anything) and I noted that the Wiring Panel Assembly did not have a cover. I wondered if I had misplaced it or it simply was never delivered. This is the vertical panel in front of the fuel selector used for channeling all the electrical wiring up into the panel sub-assembly.
I emailed support at Vans and Joe Blank very kindly (as usual) sent back a copy of Section 59 titled Power Module Install. He said it was hot off the press just yesterday. I am unable to attach a copy - I don't have sufficient IT skills. The plans show a 45 degree module that houses all the blade type fuses. As I have install a VPX I wont be using this module and will be cutting a blank to cover the current hole. For your information.
Perhaps someone with IT skills might be able attach a copy of the section 59 plan?
