I have the switch with the start function
I had the same problem and searched forever for the ACS wiring diagram and found out that with my "shower of Sparks" I needed to have a certain ignition switch and wire it accordingly.
You should let us know if you are running impulse mags, shower of sparks, or the new electronic mags that might help to know what you need.
Wiring was so much simpler with Bob Nuckolls book. I bought the Vans wiring kit for my RV 7 but it was such a dud, very little info on how to wire and it was set up for a totally different system. So I would define your ignition system and buy that AeroElectric Connection by Bob Nuckolls, you will not go wrong there.
Good luck
Wire power through a 5Amp fuse or breaker to the "Bat" terminal. Wire the "S" terminal to the "S" on you starter solenoid. L goes to the left mag using 18AWG shielded wire. Cut the shield on the switch side, then tie the center conductor to the P-lead and the shield to the Gnd screw on the mag. Same for the right mag, except there is a Gnd port next to the R terminal on the switch that will get a little bridge jumper to ground the right mag when starting because it won't be retarded. Then there is a Gnd port in the middle of the switch that gets an airframe ground. There will be an LR and another port that will get nothing.
Now I'm confused. I didn't think the GND from the key switch also went to the airframe ground. Aeroelectric only has the ground at each mag.
Here's my set up-
Slick mag on left with retard breaker, Lightspeed on right (will use LS to start engine). No shower of sparks on left mag.
Using the ACS A-510-5 key switch (without START position) and a momentary button to engage the starter. Left mag P-lead shield grounded to mag. LS wired per installation instructions.
Do I need to tie the shields from both P-leads to the GND terminal at the switch and does this terminal get grounded to the air frame?
