I'm nearing the end of my fuselage wire routing chaos, at least up to the firewall. Quick question re: coax - I've kept the coax as separated as is realistically possible in a small airframe. The bottle neck point is where it all comes together in the center tunnel under the fuel pump. Is it okay to bundle two or three coax lines together with the rest of the wire for this run through the tunnel and up the firewall, or do I need to pull the coax out and run it separately? Either way it's going to come together once it goes vertical at the firewall, so my assumption is the short runs together down the tunnel aren't a problem, but looking for more experienced eyes. It's still a work in progress, so yes, I know it's a mess.
