Wing skin - pro seal - section 31
JoeB15
Active Member
On page 32 or section 31 it says to seal the overlaps with pro seal. Has anyone done this step? I don’t understand how sealing After riveting is going to work….wouldn't you want to add some pro seal Before you rivet?
The picture in the bottom right corner seems to show the sealant under the top skin only. So I agree, it would need to be done before the top skin is riveted
The way I read that they just wanted us to push some proseal into the gap where the joggle of one skin overlaps the other. Sort of push some in and form a small fillet there. I agree, though - doing it during assembly would probably be better. I scuffed and primed the overlaps on mine.
I wondered also why there are not spacers on some of these other skin overlaps - as on the J stringers near the tank. On the aft spar inboard overlap there is a definite bend in the skin that I think would have benefitted from a couple of those spacers
I did it in the last couple of days with no problem. I sharpened a popsicle stick to a point, made up a tiny bit of old, out-of-date Proseal on a little pallet, then used the stick to slather it onto the required area where the skin is bulged a bit by the overlap. I used the pointed end to try to push the Proseal into the gap. Then, I wiped the area off so that just the overlap area retained the Proseal. I also carefully used Acetone to clean the skins of Proseal. In one case, I reapplied because I visually saw that I hadn't pushed the Proseal into the gap well enough. It was very simple and easy.
That’s perfect - thank you!
