Tood,
I am an EAA member but I think I already recycled the May issue. When I try to get it on line I get a blank page for some reason. I'll try again later.
Marty,
I see what you mean about the little hole in the wingtip. I am wondering if it is structurally strong enough. Also concerned about the pin slipping out - disaster! However - I wonder if it might be OK to drill that hole on through to the inside of the handhold, so that a bolt could be passed through both pieces of metal and secured so it couldn't come out. The spar end could be rested on a workbench or horse, and the pin (outboard) end could be supported on a horse, or even hung from above. Thoughts?
John
