Wing kit back ordered stuff
RNB
Sponsor
I just got an email that the following are on back order until December. Will someone please tell me what is in those kits? If my fuel tanks, flaps, and ailerons are already built, what is left for me if I am waiting on these parts?
Thank you.
BAG 1128, BAG 1201, W-11013A, W-1013E-R, W-1013E-L
Thank you.
Close tolerance wing bolts and aileron left/right brackets, aileron bracket spacer.
You can go to the vans store, search the part and bag numbers to find out what is in the bag or part description.
So will I be able to build my wings and these are just hardware items that connect it all together or will I have a kit but unable to build the wings?
I don't know what work is involved with QB wings. I would search the plans for the parts that are back ordered and see where they are used in the QB plans. That will tell the story.
Again, you can get the kit part and bag contents by searching the part numbers in the vans store.
To your question, you won’t need the close tolerance bolts until you are ready to mount the wings. The potential issue would be with the aileron brackets and spacer. You can see in the plans when they will be needed. I wasn’t able to find the first bag number you listed so not sure what is in there.
There should still be plenty to do on the wings before those parts come.
