Working on the right wing. Per the plumb bob it is swept forward 1 inch.
The wing rear spar is fully seated and touching the fuselage. The fuselage rear spar forward piece of the fork is touching the wing rib.
I marked my 5/8 distance grid on both pieces. The inside 5/8 distance on the fuselage is measured from where the two forks mate an become a solid spar.
The inside 5/8 on the wing rear spar is measured from the root rib flange.
Questions:
1. Since the both spars obviously continue in there respective directions can the inside 5/8 distance be somewhat ignored? Otherwise as you can see in my grid layout I really do not have the room to remove any materials (especially on the wing rear spar).
2. If I'm correct that the inside edge distance can be ignored, is there a good ratio as to how much material to remove to get close to a 1 inch movement at the wing tip?
Thank you,
Questions:
Thank you,
