Hello all. I'm getting closer to putting my windscreen in place and wondering if I should add some small defrost vents. It doesn't get very cold where I'm at, but sometimes windshields will fog up a bit on cool mornings.
I'm thinking about cutting a single small "U" slit on both side of center into the glare shield to make vents similar to what is on the firewall heat inlet cover. There wouldn't be fans, just heat rising through from below heater and avionics. Thoughts?
