Well I for one am knot going to get involved in this debate. I'm in knots just thinking about it. And I don't have enough popcorn.
Art
I fly in knots also.
Art
Maybe the RV-15 will have a cruise speed in MPH and a stall speed in Knots
Dick Rutan and Jeana Yeager were showing a VariEze, or maybe Long Eze, with cruise speed listed in MPH and stall speed in knots.
Airspeed indicators should be scaled from 0-100.
0 = Vso
100 = Vne
You joke, but that's basically the kind of reasoning that was used to invent the Fahrenheit scale![]()
It has to do with the type of primer used...
-Marc
I thought it was a Nosewheel vs Tailwheel thing?
But didn’t get it quite right so they needed to invent the centigrade scale.
And a statue mile is modern? Statute mile is the result of Roman influences and plowing oxen.Knots is a really old unit that originated with square-rigged sailing ships, and I still don't know how that seemed like modernization to the decision makers.
The irony in this statement is that 200 mph is about 170 kts, not 160![]()
I like to think that knots are preferred because it seems when boat guys get tired of throwing their money into a hole in the water, they buy an airplane.
I realize this thread is more than a year old, but since so much of the thread was getting into the details...Back in the day all planes were in MPH before 1969. After 1969 they progressively transitioned to knots/hr for airspeed and knots for distance.
Anyone look at/use the new international version of a flight plan? For cruising speed there are only 2 options: Mach number (enter "M") or Knots (enter "N"). "N"? I know English spelling can be hard, with silent "K's", but really, 'N'?I realize this thread is more than a year old, but since so much of the thread was getting into the details...
The above statement is incorrect.
We do not use knots/hr for airspeed. Knots is already an airspeed, which is "nautical miles per hour". Knots/hr would mean "nautical miles per hour per hour", which is a rate of acceleration.
Similarly, we do not use knots for distance. Knots is a speed. We use nautical miles for distance.
The world is out of sync with the USA on almost all units.By world convention (I.C.A.O) the unit for speed is KNOTS. It is mainly only the USA that has the confusion.
I might propose:I might propose:
0 = Sitting still (Need to verify "Airspeed Alive" on take off roll)
Min = Vso
Max = Vne
0 degrees = dead.Fahrenheit:
100 degrees = Human body temperature +/- 5%
0 degrees = You're dead
To answer a question some of you may have, the zero point was chosen as the stable temperature of a saturated solution of ammonium chloride mixed with water ice, which achieves a very specific temperature when mixed. Conveniently, the freezing and boiling points of water happen to be nearly 180 degrees apart, as an interesting physical metaphor.
