Whole airplane stand
Stewbronco
I may need to jack up my RV4 ( no problem …have excellent jacks ) ….but then need to remove engine and mount for some possible fuselage work . Looking for ideas on how to support the underside of fuselage / wing for some longer term work with the engine mount / gear off the plane . Jacks are very stable but in this case I am very much “ a belt AND suspenders “ kind of guy! Many thanks….pictures would be very much appreciated
Angle iron legs
With the engine and mount off, just make two legs that bolt on the fuse with mount bolts at the firewall. Get fancy and put some HF wheels on the end of the legs. X brace them for “suspenders”.
Ghetto gear
What Larry said; or, just leave your airworthy aircraft on the wrong side of town overnight.
HF snowmobile/motorcycle lift under the belly supported by the spar, with good padding seems to be a popular choice, tail weighted down appropriately, with some correctly sized and padded sawhorses under each wing, about 1/3 the way out from the fuselage.
When I had to take the mount and legs off my Rv-3, I bought an ATV/Quad Bike lift. Made a wooden saddle to fit the belly and add some height, which supported the aircraft on the mainspar carry though.
Worked great!
If it’s not notched already, I would add the firewall modification for a CS prop governor.
