Stein and Bill,
Thanks for the heads-up. Didn't get to call Dynon today before blasting off, but long IND overnight, so will call tomorrow. This is a fork in the road, as I drilled out the floor rivets to install the comm antennas in new locations, and want to re-rivet them so I can fly before the AP is shipped (and to OSH if I get the rest of the work done in time!) Having seen the debate on nutplates vs. rivets, I was sticking with rivets, so this may complicate things a bit.
The roll servo may fit in the center area which is accessible via screws, but I'll have to look at it when I get back home. Stein, in your experience, have you seen the roll servos fit in that accesible center section (might be a dumb question!). Also, what is the reason that you have seen -6 servos in the fuse rather than wing...space in the wing; geometry differences? Just trying to get smart on this so I do it right...and thanks again for the heads-up!!
Bob
