Which Red Cube transducer for the -10?
9GT
Friend
I am working on the fuel delivery system in the tunnel on my -10. I am using a Skyview EFIS and read here that the EI Red Cube transducer is about the best. My engine is an IO-540 V4A5. Is the FT-60 transducer the one I need or is a different model required? :confused:
Red Cube
There is only one red cube FT 60.
But the price can be as much as $100 different from one vendor to the next.
I think Dynon has the best price.
I have the same in my 10.
The FT-60 (Red Cube) is for low-wing aircraft with < 300 HP (Even if your IO-540 dynos for more than that).
The FT-90 (Gold Cube) is for high-wing gravity fed aircraft OR for aircraft with flow between 300 and 500 hp.
Unless your RV-10 will draw 90GPH or have wings above the cabin :eek:, you'll want the standard FT-60.
